Byte Alignment
hi there,
I am using Keil µVision 4 with NXP LPC11U35. I want to load a structure that contains mix type of variables (chars, integers, longs) using a char pointer. How can I set byte alignment so that no data are missed at the alignment?
Thanks in advance.
  • I have used the following code with no success. I am still missing data at char variables:
    effort 1:
    typedef __packed struct{
            unsigned char  soh;
            unsigned short sender;
            unsigned short receiver;
            unsigned char  trq;
            unsigned int   command;
            unsigned short packet;
            unsigned char  stx;
            unsigned int   address;
            unsigned char  data[MAX_DATA_LENGTH];
            unsigned int   crc;
            unsigned char  etx;
            unsigned short checksum;
            unsigned char  eoh;
    }RS485_FRAME;
    effort 2:
    #pragma push
    #pragma pack(1)
            unsigned char  soh;
            unsigned char  trq;
            unsigned char  stx;
            unsigned int   crc;
            unsigned char  etx;
            unsigned char  eoh;
    }RS485_FRAME;
    #pragma pop
  • sorry my bad...
    this works
            unsigned char  soh;
            unsigned char  trq;
            unsigned char  stx;
            unsigned int   crc;
            unsigned char  etx;
            unsigned char  eoh;
    }RS485_FRAME;
