Serial Port Driver for Philips LPC17xx
I need Serial Port Driver for Philips LPC17xx?????????????????????????
For ppp Connection with null modem cable
  • #include <LPC17xx.H>
    #include "..\main.h"
    #include "uart_driver.h"
    #include "..\gpio\gpio_driver.h"
    void UART_Init(UARTNo_Type Uartno, uint16_t Baudrate)
            uint32_t least_val;
            LPC_SC->PCLKSEL0 &= ~(3<<6 | 3<<8);
            switch (Uartno)
                    case UART0:
                            LPC_PINCON->PINSEL0 |= (1<<4) | (1<<6);
                            LPC_UART0->THR = 0;
                            LPC_UART0->LCR = 1<<7;
                            least_val = (uint16_t) (12000000/(16*Baudrate*1.5f));
                            LPC_UART0->FDR = (2<<4) | (1<<0);
                            LPC_UART0->DLL = (uint8_t)least_val;
                            LPC_UART0->DLM = (uint8_t)least_val >> 8;
                            LPC_UART0->LCR = 0;
                            LPC_UART0->FCR = 0x07;
                            LPC_UART0->LCR = 0x03;
                            LPC_UART0->TER = (1 << 7);
                            LPC_UART0->IER = UART_IERBR | UART_IETHRE;
                            NVIC_EnableIRQ(UART0_IRQn);
                            Rx0BufCntr = 0;
                            gUART0_BusyFlg = UART_IDLE;
                    break;
                    case UART1:
                    break;
                    case 2:
                            LPC_SC->PCONP |= PCUART2;
                    break;
                    case 3:
                    break;
    /*---- END OF UART_Init() ----*/
    void UART_TxByte(UARTNo_Type Uartno, uint8_t Data)
            volatile uint8_t temp;
            switch (Uartno)
                    case UART0:
                            do
                                    temp = LPC_UART0->LSR;
                                    temp &= 0x60;
                            }       while(temp != 0x60);
                            LPC_UART0->THR = Data & READ_1BYTE;
                    break;
    /*---- END OF UART_TxByte() ----*/
    void UART0_IRQHandler(void)
            uint8_t interrupt_status, line_status, rxdata;
            static uint8_t crflg=0;
            uint8_t dummy=dummy;                                                            //dummy is never used. hence it generates warnings. This line is written to remove the warnings.
            interrupt_status = 0x07 & (LPC_UART0->IIR >> 1);
            if(interrupt_status == UART_RDA)
                            rxdata = LPC_UART0->RBR;
                            switch(rxdata)
                                    case SOF:       //Don't store Start of Frame Character
                                            if(gUART0_BusyFlg == UART_IDLE)
                                                    Rx0BufCntr = 0;
                                                    gUART0_BusyFlg = UART_BUSY;                     //gRx0_CompleteFlg = RX_BUSY;
                                                    gUART0_IntFlg=0;
                                    break;
                                    case CR:
                                            crflg = 1;                                                              //Indicates 10 received
                                            gRx0Buf[Rx0BufCntr++] = CR;
                                    break;
                                    case LF:
                                            if(crflg)                                                               //Check for a valid CR received. For Command no 10 & 13, this needs to be checked.
                                                    --Rx0BufCntr;
                                                    gRx0LRC = gRx0Buf[--Rx0BufCntr];
                                                    gRx0Buf[Rx0BufCntr++] = NUL;
                                                    gRx0Buf[Rx0BufCntr] = NUL;
                                                    gUART0_IntFlg = 1;
                                                    UART0_DisableRx();
                                                    isr_evt_set (TASK_RX,TID_TxRxDisplayData);
                                                    Rx0BufCntr = 0;
                                            else
                                                    gRx0Buf[Rx0BufCntr++] = rxdata;
                                    break;
                                    default:
                                            crflg = 0;
                                    break;
                    if(interrupt_status == UART_THRE)
                            line_status = LPC_UART0->LSR;
                            if(gTx0Buf[Tx0BufCntr] != NUL)
                                    LPC_UART0->THR =  gTx0Buf[Tx0BufCntr++];
                            else
                                    Tx0BufCntr = 0;
                                    UART0_EnableRx();       //enable reception
    /*---- END OF UART0_IRQHandler() ----*/
    /*~~~~ END OF FUNCTIONS ~~~~*/
    The code is as it is. Works fine for me, but No warranty.
    PS: it may even damage your circuit.
    You need code. Hire a consultant.
