Hello, I'm new to ARM and Keil tools. I'm using Keil uVision V4.71.2.0. Compiler is Armcc.Exe. Compiler version is v5.03.0.69.
I'm working on large code base. When I try to build code, I get the following error:
Build target 'proj1_Debug' compiling RTX_Config.c... C:\Keil\ARM\RV31\INC\RTX_lib.c(185): error: #29: expected an expression Target not created
In RTX_lib.c, line 185 looks is as follows:
#if (__ARM__ && __RTA_RTX_CONFIG)
what might me the problem? Thanks in advance.
I have continuted the question on the previous thread.
