use of static , is it helpful
Using keyword static at modular level , i.e functions/variables which are used in same module only are declared as static, is it helpful in generating better code.
I read in 8051 declaring static at modular level is good ,as it helps in generating smaller code. Because compiler can now use ACALL inst. instead of LCALL. So faster calling & smaller code is generated.
Does samply apply to cortex M3 or not ? There is no ACALL or LCALL in it but is there any similar to it.
