WHEN I AM TRYING TO USE TIMER 2 IN 89S52 AS BAUD RATE GENERATOR .MY uVISION IS NOT RECOGNIZING THESE REGISTERS(TCLK,T2CON).WAT DO I DO..HELP NEEDED ASAP
Fix your caps lock, and then check if you include the header file for the correct processor. If you do, then open the file and have a look at it. Doesn't sound too hard, does it?
Fix your caps lock Absolutely.
it simply means that keil cannot find the correct definitions and/or declarations. Have you included the proper header file?
Do i have to include any header file in asm lannguage(software uvision3).could you please specify which one for atmel 89s52.Sorry for being such a bother but this is the first time i am using this lang and i am on a deadline.. thnk u all( caps lock is not an issue) and i hav selected this device while starting the project in uVision
NEVER EVER USE THE SMS TEXTING LANGUAGE ON FORUMS. Does not sound COOL, Dude. Save it for you friends and to impress girls. ;)
You DON'T have any character restrictions (as in SMSes. 160 characters only). And you dont even get charged as per the number of characters that you type. So use proper punctuations, spellings, etc. People on forums are professionals. And your professionalism will be appreciated.
especially... Save it for you friends and to impress girls. ;)
Dear sir, I am grateful for your helpful reply. Thanking You Yours sincerely, Mayank Vats
will you not like to share the solution of the problem?
