C:\KEIL\C51\INC\REG51.H(13): error C129: missing ';' before 'sfr'
Just wondering any ideas about this error. Can't find any missing ';'
Note that missing ';' aren't visible.
So how did you look?
And in what context was the file included? A problem before the #include line kan result in lots of funny errors.
Well - if it's missing, then you won't find it!
Seriously, though, this is often the result of some other error where the only way the compiler can see to get back "in-sync" with your source text is by assuming that there should've been a semicolon at the point indicated.
Are there any other errors preceding this?
In particular, look out for undefined symbols, type names, and preprocessor macros...
In that location, I would expect that to be one of Keil's supplied headers - is it? If it is, have you messed with it?
That's pretty early in the file (line 13) - could it, perchance, be the first non-comment line after the header comment? If it is, the error may be immediately before the #include line for this header...
could it, perchance, be the first non-comment line after the header comment? when I lose a few of the strands of the hair I have left hunting for something like this, it is often because the cause is in the preceding included file.
