LPC2387 IAP Flash Erase
Hey everyone, was hoping someone could help me with something.
I'm developing an RTX application for a LPC2387 (currently using the MCB2300) and need to write a char array to flash memory. Learned a lot about using IAP commands but I think I'm missing something still.
I'm using function inspired by the supplied algorithms for the LPC2387 (found under C:\Keil\ARM\Flash). I can write to flash and read it back fine but once I try to erase, I get a data abort exception. My code is below:
This works:
    flash_write(0x00058000, protocol_buf1);
    flash_read(0x00058000, 5, protocol_buf2);
    // Code that prints out protocol_buf2
This doesn't work:
    flash_erase(0x00058000);
Where the flash functions are defined:
#define CCLK        4000
#define PAGE_SIZE   1024
struct sIAP {                  // IAP Structure
  U32 cmd;           // Command
  U32 par[4];        // Parameters
  U32 stat;          // Status
  U32 res;           // Result
} IAP;
void    IAP_Execute (struct sIAP *pIAP);
U32 get_sect_num(U32 address) {
    U32 sector;
    // Calculate sector number
    sector = (address >> 12) & 0x7F;
    if (sector >= 0x78) sector -= 0x62;
    else if (sector >= 0x08) sector  = 0x07 + (sector >> 3);
    return sector;
U8 flash_write(U32 address, U8 *buffer) {
    U32 sector;
    // Get the sector number
    sector = get_sect_num(address);
    // Prepare sector for write
    IAP.cmd = 50;               // Command code
    IAP.par[0] = sector;        // Start sector
    IAP.par[1] = sector;        // End Sector
    IAP_Execute(&IAP);          // Execute IAP Command
    if (IAP.stat) return 1;     // Command Failed
    // Copy RAM to FLASH
    IAP.cmd = 51;               // Command Code
    IAP.par[0] = address;       // Destination Flash Address
    IAP.par[1] = (U32)buffer;   // Source RAM Address
    IAP.par[2] = PAGE_SIZE;     // Fixed Page Size
    IAP.par[3] = CCLK;          // CCLK in kHz
    return 0;
U8 flash_read(U32 address, U32 size, U8 *buffer) {
    U32 i;
    for (i=0; i<size; i++) buffer[i] = *((U8*)address+i);
    return 0;
U8 flash_erase(U32 address) {
unsigned long n;
  n = (unsigned long)get_sect_num(address);                          // Get Sector Number
  IAP.cmd    = 50;                             // Prepare Sector for Erase
  IAP.par[0] = n;                              // Start Sector
  IAP.par[1] = n;                              // End Sector
  IAP_Execute (&IAP);                          // Execute IAP Command
  if (IAP.stat) return (1);                    // Command Failed
  IAP.cmd    = 52;                             // Erase Sector
  IAP.par[2] = CCLK;                           // CCLK in kHz
  return (0);                                  // Finished without Errors
assembly IAP execution
                AREA    IAPEXE, CODE, READONLY
;void IAP_Execute (struct sIAP *pIAP); EXPORT IAP_Execute
IAP_Execute STMFD SP!,{LR} ; Save Return Address ADD R1,R0,#0x14 ; R0 = &IAP.cmd, R1 = &IAP.stat ADR LR,IAP_Exit ; Return Address LDR R2,=0x7FFFFFF1 ; IAP Entry (Thumb Mode) BX R2 ; Execute IAP Command
IAP_Exit LDMFD SP!,{LR} ; Restore Return Address BX LR ; Return
END
