Hello, I use the RENAMECLASS Pragma for several sections and it works fine. For some reason it doesn't work with ICODE. The compiler says "unknown class". But the ICODE class is used several times and works fine without that pragma.
The rec.lin is used in the project options (tab L166 MISC) and ICODE is defines there.
I can't think of any reason why the compiler won't accept the ICODE class with the RENAMECLASS pragma.
Best Regards
