UART ISR() not triggering with RTX/ADUC7020
Hello all,
I'm using RTX and ADUC7020 processor and have a problem with the UART ISR routine where the ISR isn't triggering when UART data is sent to it.
In my main(), I have:
        GP1DAT |= 0x8C000000;
        REFCON = 1;
        //Set Baud for 9600bps
        COMCON0 = 0x80; //Set DLAB to access COMDIV
        COMDIV0 = 0x88; //Low byte
        COMDIV1 = 0x00; //High Byte
        COMCON0 = 0x03; //clear DLAB and set serial for 8,N,1
        COMIEN0 = 0x07; // enable interrupt when buffer is full during a reception.
                        // enable interrupt when buffer is empty during a transmission
                        // enable generation of an interrupt if any of COMSTA0[3:0] is set.
        IRQEN |= 0x4000;
In my rtx_config.c, I have changed the following from the default:
/*--------------------------- IRQ_Handler -----------------------------------*/
// User Interrupt Functions
//extern __irq void IRQx (void);               // User IRQx Function
extern __irq void IRQy (void);                 // User IRQy Function
//#define mIRQx       0x00000080               // User IRQx Mask
#define mIRQy       0x00004000                 // User IRQy Mask
__asm void IRQ_Handler (void)
   // Common IRQ Handler
        PRESERVE8
        ARM
        STMDB   SP!,{R0}                       ; Save R0
        LDR     R0,=__cpp((U32)&IRQSTA)        ; Load IRQSTA Address
        LDR     R0,[R0]                        ; Load IRQSTA Value
//      TST     R0,#mIRQx                      ; Check IRQx Flag
//      LDMNEIA SP!,{R0}                       ; Restore R0
//      LDRNE   PC,=__cpp(IRQx)                ; IRQx Function
        TST     R0,#mIRQy                      ; Check IRQy Flag
        LDRNE   PC,=__cpp(IRQy)                ; IRQy Function
        TST     R0,#(SWI_BIT :OR: RTOS_TIMER_BIT) ; Check OS IRQ Flag
        LDMIA   SP!,{R0}                       ; Restore R0
        LDRNE   PC,=__cpp(os_clock_interrupt)  ; OS Clock IRQ Function
        LDR     PC,=__cpp(os_def_interrupt)    ; OS Default IRQ Function
And finally, I have the ISR function that's also in the same source as main()
__irq void IRQy(void)
    /*if (IRQSIG & 0x00000008)
        timer1_handler();
        if (IRQSIG & 0x00004000)
                uart_handler(); // break point here
I have a break point on uart_handler() but it doesn't hit when I send UART data to it. I have a non RTX version that's configured the same and the break point hits everytime. Is there something I forgot to do? Any help is appreciated.
  • One thing I forgot to mentioned is that on ADUC7020, UART interrupt bit is 14, which would be 0x4000. This information is on page 63 of ADUC702x data sheet.
  • I apologize for not having all the information under one post. In the UV4 under Peripherals menu, both the Interrupt Controller and UART dialog are showing the UART interrupt is setup using RTX.
    Here are some register values of interest when I paused the system while UART data is continuously sent to the ADUC7020:
    IRQSIG: 0x00048004
    IRQEN: 0x00004004
    IRQSTA: 0x00000004
    COMIEN0: 0x07
    COMCON0: 0x03
    COMSTA0: 0x60
    Thanks,
    Shane
