I work with an LPC3250 board. i try to write a "long int" value into the SDRAM at address X through a "long int *" pointer. but the value will be written at address (X-2). if I write into the RAM in the same way or if write the value Byte by Byte into the SDRAM there are no problems detected. Any help would be extremely appreciated
