hi
i am using arm 9 board(samsung s3c2440), and i am doing the simple program to recognize user button from user led . actually there is no error in this program but this program is not working properly....." #include "def.h" #include "2440addr.h"
void delay(int x) { int i,j; for(i=0;i<=x;i++) { for(j=0;j<=x;j++) {}}
int main (void) { rGPGCON=0x000000; rGPGUP=0x000000; rGPBCON=0X0015400; rGPBUP=0x000000;
while(1) { while((rGPGDAT)&(0x0800)==0x0800) {rGPBDAT=~0x020;} while((rGPGDAT)&(0x080)==0x080) {rGPBDAT=~0x040;} while((rGPGDAT)&(0x040)==0x040) {rGPBDAT=~0x080;} while((rGPGDAT)&(0x020)==0x020) {rGPBDAT=~0x100;}
}" the problem is that all leds are recognizing with only one user button randomly. and no other buttons are working except 1st. help me what is the problem?
Error 1: You ignored the information how to post source code. Clearly visible directly above the input message box.
Error 2: You totally forgot comments in your code.
Error 3: You expect the readers to know how you have connected your processor, i.e. where you have buttons and where you have LEDs.
Error 4: You love magic constants in your code.
Error 5: You are playing with infinite loops without caring about how the code execution gets stuck there and during that time will not look at other buttons.
Error 6: You continue to assign for a LED as long as you see a button pressed - how many times do you think the processor will manage to see the button press before you finally release the button?
Error 7: You haven't considered how your code should be able to either toggle a LED, or perform a set or reset based on detected button state. Just assigning rGPBDAT = ~SOME_CONSTANT isn't managing that.
sorry for that . but this is a ready made board. and i have used "if" statement also but the same problem is coming(error 5,6).and these constants are codes to switch the each led. there are 4 leds connected with port B(high enable) at pin 5,6,7 and 8.port B is 11 bit port and user buttons(NO) are connected with port G at 0,3,5,6,7 and 11.
So - your problem should have been solved if you had worked through my list.
Have you considered maybe having code that can both turn on - and turn off - a LED? Code that can only turn on - or only turn off - a LED is rather boring.
