Hi
How to increase the stack size , i am not using the RTX. Where i have to increase (which file).
thanks and regards Goran.
Let's assume that the stack needs to be configured _before_ the program reaches main().
Do you then get any idea what potential file to take a closer look at?
Thank you for the information , i got the answer (startup file )
DO NOT MAKE THE STACK SIZE LOTS BIGGER THAN RAM MEMORY YOU HAVE.
Can you back up your statement with some hard facts - like why it is worse to have a stack that is four times as large as the available RAM compared to a stack that is only three times as large than the available RAM?
