www.keil.com/.../armccref_chdcdggg.htm
It says, "The use of --apcs=/ropi is not supported when compiling C++. You can compile only the C subset of C++ with /ropi."
What dose it mean by "the C subset of C++" ? Which part of c++ is not supported? nonvirtual member function ? virtual function ? or exception handling ?
I kept reading the ELF specification and drawing the structures for it for about three hours
It appears you are not the only one:
stackoverflow.com/.../linux-user-space-elf-loader
If you cannot find existing code that does most of the work, why don't you take a library for reading ELF, parse a simple executable and implement relocations that you encounter one at a time. I think it is reasonable to expect that Cortex-M3 executables will only use a smaller subset of the full spec.
You continue to talk about "load apps dynamically".
You can load apps dynamically without any extra work. You don't need relocation tables to load apps dynamically. The relocation is only needed if the load address is decided dynamically.
A normal boot loader loads apps dynamically. Just that the apps loaded are normally already linked for running at the load address the boot loader places them at.
The question is - why do you need to load apps at a dynamically selected load address? And how are you going to manage to get two concurrently loaded applications to share processor time? If they can't - what specific advantage do you then see of having another app loaded, that isn't allowed to run?
Linux systems have totally different needs since you can _never_ get away with linking an application for a fixed address - it all depends on what other things you already have loaded in memory. That totally beside the fact that a "normal" Linux system uses a processor with a MMU making the applications memory accesses to be mapped from logical address space to physical address space.
So - how about finally post some specific reasons why you feel a need for your loader to decide the actual load address dynamically.
I'd like to know that too. So far my impression is that he wants to familiarize himself with some cool new technology in his spare time. Although I do think that he could pick a technology that would be more beneficial in terms of employment prospects.
Per Westermark ---------------------------------------------- how about finally post some specific reasons why you feel a need for your loader to decide the actual load address dynamically?
There's no actual need in fact. I'm still at college. Programming entertains me somehow. I just want to implement an simple flexible multitasking system. It does not have to be powerful, though, I want it to behave a little bit like a PC's os. So then I could be familiar with a simple system.
The code for passing control is very simple (I'm not talking about scheduling algorithm). In the systick timer handler function, you can push the registers into stack, (call a scheduling algorithm function to get next task's sp) and change the sp to point to another task's stack, pop the protected variables into register, and then finally the inturrupt handler returns. (for CM3, the return address is push into the stack by hardware when an Inturrupt occurs, and the address is reloaded to PC register when the hanler returns). As for The scheduling algorithm, I haven't implemented it yet. The Round-Robin scheduling may be used for first implementation.
Mike Kleshov ----------------------------------------------
Thanks for the information you provide. I'm not good at searching for these, because English is not my first language and I'm not quite used to read english web page.
It's not some cool new technology. Actually I think I'm just trying to "re-inventing the wheel". Things about operating system always interest me. Knowing about it is not enough for my curiosity. So why not do it myself when I have time. I think I may not have as much time as now after graduation and getting a job.
It takes time. I'm not a native English speaker either. But you better get used to reading lots of (technical) English if you are goiing to persue a career in electronics and/or programming. Luckily, technical English appears to be the easier subset of the language :-)
"Luckily, technical English appears to be the easier subset of the language :-)"
I'm pretty sure there are a huge number of native english speakers who do not agree on that :)
Anyway - consider the PC.
MS-DOS didn't have multitasking.
Windows have multitasking. But the applications do not own interrupt handlers - they are owned by the operating system as shared resources for the applications to alocate and use. It gets interesting when you have two completely different embedded applications that wants to interface with the hardware and install interrupt handlers. There is only one interrupt controller.
Multitasking two embedded applications is harder than multitasking two desktop applications.
Another thing here is that if you relocate an application, you can have it running at a different address. But how will you know what RAM memory ranges it needs? Because the second application must not use the same RAM regions. Having relocation entries for all RAM accesses isn't enough to be able to also know how much RAM that is used. Next thing is that the ARM instruction set often don't allow arbitrary accesses unless all accesses are made relative to an index pointer. In many situations, registers are loaded with constants of limited width with an optional shift. And same with memory accesses - offsets or absolute addresses are compressed to a limited width with an optional shift. So you can't get away with a relocation table that updates 32-bit memory values with an extra offset. So you may need to have the compiler produce accesses relative to a common pointer.
In short - the number of problems to handle tends to add up, making some projects cost much more than the expected gain. Settling for just two applications at a time, and linking every application twice - one "low" and one "high" link - is a way easier way of writing code that can load two-of-n applications and then have them multitask concurrently.
How do you compare the effort (cost) of building the aforementioned system with the gain of satisfying somebody's curiosity? I think labour cost is a factor here. Once the OP starts making good money as an engineer (and I do hope he does), he'll be more careful with his time :-)
