Hi, I am having problems with STM32F103RB in MCBSTM32 with Keil UVision. I am trying to use the TIM2 interrupt on DMA USART with tasks. The problem is that the interrupt never happen. Sure that I am missing something. I put the resume of the code below and all the project and stuff on .rar. I use the file STM32_Init.c I test the code sending stuff by the serial port and the interrupt didnt occur. When I set the os_event_set I receive stuufs, the code works.
The project: www.4shared.com/.../TASK_INTERRUPT_MODBUS.html
*----------------------------------------------------------------------------*/ #include <RTL.h> /* RTX kernel functions & defines */ #include "stm32f10x_lib.h" /* STM32F10x Library Definitions */ #include "STM32_Reg.h" /* STM32 register and bit Definitions */ #include "STM32_Init.h" /* STM32 Initialization */ #include "LCD.h" /* LCD functions prototypes */ #include "stm32f10x_nvic.h" #include "stm32f10x_it.h" __task void task_init (void); __task void task_rece_USART (void); __task void task_display (void); OS_TID tsk3,tsk4; void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; #ifdef VECT_TAB_RAM NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0); #else NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); #endif NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel5_IRQChannel; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel4_IRQChannel; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } void DMA_UART_Init (void) { RCC->AHBENR |= (1<<0); /* enable periperal clock for DMA */ /* Enable DMA channel5 IRQ Channel */ DMA1_Channel5->CMAR = (unsigned long)& Recepcao_Modbus[0] ; /* set chn1 memory address */ DMA1_Channel5->CPAR = (unsigned long)&(USART1->DR); /* set chn1 peripheral address */ DMA1_Channel5->CNDTR = 100; /* transmit 3 words */ DMA1_Channel5->CCR = 0x00000082; /* configure DMA channel 1 */ /* circular mode, memory increment mode */ /* memory & peripheral size 16bit */ /* channel priotity high */ DMA1_Channel4->CMAR = (unsigned long)& Mensagem_Modbus[0] ; /* set chn1 memory address */ DMA1_Channel4->CPAR = (unsigned long)&(USART1->DR); /* set chn1 peripheral address */ DMA1_Channel4->CNDTR = 0; /* transmit 3 words */ DMA1_Channel4->CCR = 0x00000092; /* configure DMA channel 1 */ /* circular mode, memory increment mode */ /* memory & peripheral size 16bit */ /* channel priotity high */ USART1->CR1 = 0x0000200C; USART1->CR2 = 0x00000000; USART1->CR3 = 0x00C0; USART1->BRR = 0x1D4C; DMA1_Channel5->CCR |= (1 << 0); /* enable DMA Channe1 */ } __task void task_init (void) { tsk4 = os_tsk_create (task_display, 2); tsk3 = os_tsk_create (task_rece_USART, 3); os_tsk_delete_self(); /* End initialization task */ } __task void task_display (void) { for (;;) { //lcd_clear(); set_cursor(0,1); lcd_print (" Task2"); /* sprintf(msg_buf, "%d ", tim2_teste); set_cursor(0,1); lcd_print(msg_buf); */ os_dly_wait (10); /* Wait 100 ms and display again */ // os_evt_set (0x0001, tsk3); } } __task void task_rece_USART (void){ unsigned int indice_modbus = 0, max, tamanho_pedido; unsigned int CRC2, crc_hi, crc_low, ind, des; unsigned char *ptr_char; for (;;) { if (os_evt_wait_or (0x0001, 0xFFFF)){ //INTERRUPT NEVER HAPPEN os_evt_clr (0x0001, tsk3); code..... } } int main (void) { //int i; OFFSET_aux = (int)(OFFSET *0.02); stm32_Init (); /* STM32 setup */ TIM2->CR1 = 0x0000; NVIC_Configuration(); DMA_UART_Init(); os_sys_init (task_init); /* Initialize OS and start init task */ } ///////////////////////////////////////stm32f10x_it.c///////////////////////////////////////////// void DMA1_Channel4_IRQHandler(void){ if((DMA1->ISR & 0x00001000) || (DMA1->ISR & 0x00002000)) { DMA1->IFCR = 0x00001000; DMA1_Channel4->CCR = 0x00000092; /* configure DMA channel 4 */ DMA1_Channel4->CNDTR = 0; DMA1_Channel5->CCR = 0x00000082; /* configure DMA channel 1 */ DMA1->IFCR = 0x00010000; DMA1_Channel5->CNDTR = 100; /* transmit 3 words */ DMA1_Channel5->CCR |= (1 << 0); /* enable DMA Channe1 */ } } void DMA1_Channel5_IRQHandler(void){ if((DMA1->ISR & 0x00010000) || (DMA1->ISR & 0x00020000)) { DMA1_Channel5->CCR = 0x00000082; /* configure DMA channel 1 */ DMA1->IFCR = 0x00010000; DMA1_Channel5->CNDTR = 100; /* transmit 3 words */ } } void TIM2_IRQHandler(void) { if ((TIM2->SR & 0X0041) == 0x0041){ TIM2->CNT = 0; TIM2->CR1 = 0x0001; TIM2->SR &= 0xFFBE; }else{ if (TIM2->SR & 0x0001){ TIM2->CR1 = 0x0000; DMA1_Channel5->CCR = 0x00000082; TIM2->SR &= 0XFFFE; isr_evt_set (0x0001, tsk3); } } ///////////////////////////////////////stm32f10x_it.c/////////////////////////////////////////////
