I'v been trying to use the c++'s cout object with my stm32 (cotex-m3) board.
I think I'v reimplemented the necessary functions, after reading the related topics of the documentation, such as < http://www.keil.com/support/man/docs/armlib/armlib_CJAIABCF.htm Redefining low-level library functions to enable direct use of high-level library functions in the C library > and < http://www.keil.com/support/man/docs/armlib/armlib_cjajiegc.htm Using the libraries in a nonsemihosting environment > and so on.
The code I wrote is just like this,
#pragma import(__use_no_semihosting) #include <stdio.h> namespace std{ struct __FILE { int handle; /* Whatever you require here. If the only file you are using is */ /* standard output using printf() for debugging, no file handling */ /* is required. */ }; FILE __stdout; FILE __stdin; FILE __stderr; int fputc(int ch, std::FILE *f) { /* ... I put the char to the serial port */ return 0; }; ... } #include <stdio.h> #include <iostream> using std::cout; using std::endl; int main(void) { printf("printf: hello world!\n"); cout<<"hello world"<<endl; ... }
I've done the necessary hardware initialization in the startup code before the library init start ( call __main ).
Program work pretty well when using the software simulation. It works too when I download the code to my mcu board, only sometimes! It fails most of the times! what is more wierd is, when the mcu output char strings successfully, I turn its power off, and then turn it on, the program fails again!
I've notice that the program is abort during the program initialization (after __main and before main is called). I then re-implemented the abort() function and output "abort" in it only to found that abort is called by the lib during init.
The most distasting thing is that the library dosen't output any imformation about the error, even though I've re-implemented the _ttywrch(int ch) function!
So my question is, what may cause the c/c++ lib run time init failure ? Do I miss any step to use the std::cout in an nonsemihosting environment?
ps: I'm quite sure the heap memory is enough, I define the Heap_Size as 0x1000. It was defined 0x400 before and the program output "SIGABRT: Abnormal termination"(I don't quite get it. Why not output information such as "out of memory" ? Who wouldn't know the program has terminated without the "SIGABRT: Abnormal termination" ???).
Problem solved. I uncheck the NoInit option for the RAM, and then the program went normally.
The simulator clear the ram before the program start, so the program goes pretty well.
While using real hardware, the content of RAM is unknown after the mcu's being powered up.
I think this may be considered a bug of the library, because it cannot successfully be initialized with the "NoInit" option, which is used to tell the compiler to leave the undefined-init-value global variables alone. What's worse, the library didn't even report any useful debug information and that really make me having a hard time debuggin the program!
I can't see why the library should issue any bugs if your project settings are incorrect.
You have to realize that the tools supports programs with all assembler, or all C or mixes. And it supports multiple memory regions. In the end, it is up to the developer to make proper project settings depending on the requirements/needs.
Most people who do want uninitialized memory would probably either specify two separate memory ranges and have all normal data in the first region - complete with zeroing of memory. And then a second region configured with that noninit setting. Or alternatively, people would specify a smaller address range in the project form, and then use pointers or absolute addresses to make use of the "hidden" memory range.
But in the end, the project file has to be general enough (to support all types of projects) that many project combinations will fail to give a correct application in relation to the customers expectations.
to Per Westermark, " can't see why the library should issue any bugs if your project settings are incorrect. " you are right, I took a look at the C++0x standard, searching with the key "initialize". And found "Variables with static storage duration (3.7.1) or thread storage duration (3.7.2) shall be zero-initialized (8.5)before any other initialization takes place" Thus the "NoInit" setting is in conflict with the standard.
I used to declared zero-init variables with the "NoInit" because my previous code do the basic hardware and related software initializations before __main is call. But Now I have to give up "NoInit". Re-implementing the _clock_init function and doing the necessary basic initializations may be a good choice too.
As I mentioned, it is possible to have a project where some part of the RAM are zero-initialzed and the rest isn't. So you can get a correct environment for a C/C++ program while at the same time have some data survive a reboot.
Yes. But personally I don't like to manually divided the RAM into parts, and have the size of each part of it explicitly defined. Re-implementing a low level function like _clock_init feeds my need to do some basic initializations.
In some special case, the programmer wants to know whether a powerup or an abnormal system reset occurs, you suggestion will be good.
