STM32: USBH_BulkReceiveData() Usage
Hello!
I'm currently trying to implement a simple USB CDC Host. I used the following thread as reference: http://www.keil.com/forum/20569/ by Tsuneo Chinzei! It works well so far, I could enumerate my device and successfully used USBH_BulkSendData() to communicate with the OUT-Endpoint.
But when I use the USBH_BulkReceiveData() function the STM32 always goes into an USB-interrupt loop. Do I have to poll (HCD_GetURB_State(pdev , MSC_Machine.hc_num_in) == URB_DONE) first or maybe send an IN-Token first (if yes, which function is that?)?
  • I found a nice code example for CDC Host here:
    code.google.com/.../usb_host_cdc.c
    Is it possible that I have to use the requests for Set_Line_Coding and Set_Control_Line_State before sending/receiving my bulk packets? If yes, can I send them with USBH_CtlReq() to EP0, right?
    What is the Set_Control_Line_State request good for? I found it in the usbcdc11.pdf from usb.org but still don't really know what its purpose is.
  • I forgot to mention that my device is a CDC ACM (Abstract Control Model) class USB-sensor.
    [Port4] : URG Series USB Device Driver
    ---===>Device Information<===---
    English product name: "URG-Series USB Driver"
    ConnectionStatus:
    Current Config Value: 0x01 -> Device Bus Speed: Full
    Device Address: 0x01
    Open Pipes: 3
    ===>Endpoint Descriptor<===
    bLength: 0x07
    bDescriptorType: 0x05
    bEndpointAddress: 0x83 -> Direction: IN - EndpointID: 3
    bmAttributes: 0x03 -> Interrupt Transfer Type
    wMaxPacketSize: 0x0010 = 0x10 bytes
    bInterval: 0x10
    bLength: 0x07
    bEndpointAddress: 0x02 -> Direction: OUT - EndpointID: 2
    bmAttributes: 0x02 -> Bulk Transfer Type
    wMaxPacketSize: 0x0040 = 0x40 bytes
    bInterval: 0x00
    bLength: 0x07
    bEndpointAddress: 0x81 -> Direction: IN - EndpointID: 1
    bInterval: 0x00
    ===>Device Descriptor<===
    bLength: 0x12
    bDescriptorType: 0x01
    bcdUSB: 0x0200
    bDeviceClass: 0x02 -> This is a Communication Device
    bDeviceSubClass: 0x00
    bDeviceProtocol: 0x00
    bMaxPacketSize0: 0x40 = (64) Bytes
    idVendor: 0x15D1 = Vendor ID not listed with USB.org as of 03-19-2008
    idProduct: 0x0000
    bcdDevice: 0x0100
    iManufacturer: 0x01 English (United States) "Hokuyo Data Flex for USB"
    iProduct: 0x02 English (United States) "URG-Series USB Driver"
    iSerialNumber: 0x00
    bNumConfigurations: 0x01
    ===>Configuration Descriptor<===
    bLength: 0x09
    bDescriptorType: 0x02
    wTotalLength: 0x0043 -> Validated
    bNumInterfaces: 0x02
    bConfigurationValue: 0x01
    iConfiguration: 0x00
    bmAttributes: 0xA0 -> Bus Powered
    MaxPower: 0xFA = 500 mA
    ===>Interface Descriptor<===
    bLength: 0x09
    bDescriptorType: 0x04
    bInterfaceNumber: 0x00
    bAlternateSetting: 0x00
    bNumEndpoints: 0x01
    bInterfaceClass: 0x02 -> This is Communications (CDC Control) USB Device Interface Class
    bInterfaceSubClass: 0x02
    bInterfaceProtocol: 0x01
    CAUTION: This may be an invalid bInterfaceProtocol
    iInterface: 0x00 -> This is a Communications (CDC Control) USB Device Interface Class
    ===>Descriptor Hex Dump<===
    bLength: 0x05
    bDescriptorType: 0x24
    05 24 00 10 01 -> This is a Communications (CDC Control) USB Device Interface Class
    bLength: 0x04
    04 24 02 06 -> This is a Communications (CDC Control) USB Device Interface Class
    bLength: 0x05
    05 24 06 00 01 -> This is a Communications (CDC Control) USB Device Interface Class
    bLength: 0x05
    05 24 01 03 01
    bLength: 0x07
    bInterval: 0x10
    bLength: 0x09
    bInterfaceNumber: 0x01
    bNumEndpoints: 0x02
    bInterfaceClass: 0x0A -> This is a CDC Data USB Device Interface Class
    bInterfaceSubClass: 0x00
    bInterfaceProtocol: 0x00
    iInterface: 0x00
    bLength: 0x07
    bInterval: 0x00
    bLength: 0x07
    bInterval: 0x00
