I'm involved in a project where we use Keil uVision and the RTX kernel and am now searching for the source code for RTX in order to verify some parts of the kernel. According to your product page (http://www.keil.com/rl-arm/rtx_benefits.asp) it should be included in our MDK-ARM distribution but I can't find it. Where should I look?
Thanks, // Måns
Note that this is just a User forum - not monitored by Keil:
http://www.keil.com/forum/
You need to contact Keil direct.
Are you saying that now they removed the sources of RTX, too? Holly crap, this is getting better and better.
Doesn't mean that I can't get an answer here...
Anyway, for those looking for the source code just like me it's located in <your-keil-dir>\ARM\RL\RTX\SRC as long as you have MDK-ARM v4.20 or newer installed.
Sounds like you'll need to sign an NDA or pay top dollar ($) to get what other free packages do, and a lot better...
Why? A quick search of the Keil website showed this:
http://www.keil.com/pr/article/1253.htm
He didn't feel like being helpful but still wanted to post. Seems legit.
"Are you saying that now they removed the sources of RTX, too?"
Read again - originally, you didn't get any source with RTX.
Look into MDK installed folder under \ARM\RL\RTX\SRC\
True.
But you did adress your post as if speaking direct to Keil - so I didn't want you to be disappointed that you would (probably) not get a response from Keil themselves.
