LPC1768 - PWM not working
Hello All,
I've developed customized LPC1768 board & want PWM 4 & 6 in Double Edge mode. However it is not working. Can you please guide after looking into my code as below. O/p pins of PWM3,4,5 & 6 all shows always HIGH.
One more observation is that in the simulator mode the PWM works fine.
I've tested the respective Pins by configuring them as GPIO & LED toggle it works. But the PWM mode is not working.
Thanks & Regards
Raj
pwm.c
#include "lpc17xx.h"
#include "type.h"
#include "datatype.h"
#include "pwm.h"
#define PWM_RATE 10000
volatile uint32_t Pwm_Match0_counter;
** Function name: PWM1_IRQHandler
** Descriptions: PWM1 interrupt handler
** For now, it only deals with PWM1 match 0
** parameters: None
** Returned value: None
void PWM1_IRQHandler (void)
{ uint8 regVal;
regVal = LPC_PWM1->IR; if ( regVal & MR0_INT ) { Pwm_Match0_counter++; } LPC_PWM1->IR |= regVal; /* clear interrupt flag on match 0 */ return;
** Function name: PWM_Init
** Descriptions: PWM initialization, setup all GPIOs to PWM0~6,
** reset counter, all latches are enabled, interrupt
** on PWMMR0, install PWM interrupt to the VIC table.
** parameters: None
** Returned value: true or false, if VIC table is full, return false
void PWM_Init(void)
{ Pwm_Match0_counter = 0; LPC_PINCON->PINSEL4 = 0x05500550; /* select PWM3,4,5 & 6 func and P2.10 to 13 as interrupt */
LPC_PWM1->TCR = TCR_RESET; /* Counter Reset */ LPC_PWM1->PR = 0x00; /* count frequency:Fpclk */ LPC_PWM1->MCR = PWMMR0I | PWMMR0R; /* interrupt on PWMMR0, reset on PWMMR0, reset TC if PWM matches */
LPC_PWM1->PCR = PWMSEL3 | PWMSEL4 | PWMSEL5 | PWMSEL6; /* Double Edge selection */ LPC_PWM1->MR0 = PWM_RATE; /* set PWM cycle */
/* all PWM latch enabled */ LPC_PWM1->LER = LER0_EN;
NVIC_EnableIRQ(PWM1_IRQn); return;
** Function name: PWM_Set
** Descriptions: PWM cycle setup
** parameters: Channel number, PWM cycle, and offset
uint8 PWM_Set(uint8 channelnum, uint32 on_period, uint32 off_period)
{ switch(channelnum) { case PWM4: LPC_PWM1->MR3 = on_period; /* ON time */ LPC_PWM1->MR4 = off_period; /* OFF time */ LPC_PWM1->LER = LER3_EN | LER4_EN; /* latch new ON/OFF period */ break; case PWM6: LPC_PWM1->MR5 = on_period; /* ON time */ LPC_PWM1->MR6 = off_period; /* OFF time */ LPC_PWM1->LER = LER5_EN | LER6_EN; /* latch new ON/OFF period */ break; default: channelnum = ERROR; /* return ERROR incase wrong channalnum */ break; } return(channelnum);
** Function name: PWM_Start
** Descriptions: Enable PWM by setting the PCR, PTCR registers
** parameters: channel number
uint8 PWM_Start(uint8 channelnum)
{ switch(channelnum) { case PWM4: LPC_PWM1->PCR |= PWMENA4; /* Start PWM4 */ break; case PWM6: LPC_PWM1->PCR |= PWMENA6; /* Start PWM6 */ break; default: channelnum = ERROR; /* return ERROR incase wrong channalnum */ break; } LPC_PWM1->TCR = TCR_CNT_EN | TCR_PWM_EN; /* counter enable, PWM enable */ //???? return(channelnum);
** Function name: PWM_Stop
** Descriptions: Stop PWM channel
uint8 PWM_Stop(uint8 channelnum)
{ switch(channelnum) { case PWM4: LPC_PWM1->PCR = PWM_DIS4; /* Stop PWM4 */ break; case PWM6: LPC_PWM1->PCR = PWM_DIS6; /* Stop PWM6 */ break; default: channelnum = ERROR; /* return ERROR incase wrong channalnum */ break; } return(channelnum);
** End Of File
main.c
#include "pwm.h"
extern volatile uint32_t Pwm_Match0_counter;
int main (void)
{ /* SystemClockUpdate() updates the SystemFrequency variable */ SystemClockUpdate();
PWM_Init(); PWM_Set(PWM4, 3000, 9000); PWM_Set(PWM6, 2000, 8000); PWM_Start(PWM4); PWM_Start(PWM6);
while(1) { if(Pwm_Match0_counter != 0) { Pwm_Match0_counter = 0; PWM_Set(PWM4, 3000, 7000); PWM_Set(PWM6, 5000, 8000); } }
  • ... is to learn to follow directions.
    such as how to post code. Did you really believe that anybody could make head or tail from what you saw in preview?
    thus, if you followed the directions in the litterature concerning your part, you just might have a working chip.
  • Hello Eric,
    Thanks for your reply & guidance.
    I've formatted the code & previewed. Here there are 2 files main.c- has logic to call PWM init, start etc and pwm.c - this has all the pwm functionality code like pwm_init, pwm_stop etc.
    Kindly let me know your feedback about the code fault.
    Thanks & Regards
    Raj
    /*********************** Start of pwm.c File ********************************/
    #include "pwm.h"
    int main (void)
    ** End Of main.c File
    #include "type.h"
    #include "pwm.h"
    ** parameters: None
    { uint8 regVal;
    ** Function name: PWM_Init **
    void PWM_Init(void)
    LPC_PINCON->PINMODE4 = 0x00000AA0; /* No Pull-up/down for PWM3,4,5 & 6*/ LPC_PWM1->TCR = TCR_RESET; /* Counter Reset */ LPC_PWM1->PR = 0x00; /* count frequency:Fpclk */ LPC_PWM1->MCR = PWMMR0I | PWMMR0R; /* interrupt on PWMMR0, reset on PWMMR0, reset TC if PWM matches */
    ** Function name: PWM_Set **
    ** Descriptions: PWM cycle setup **
    ** parameters: Channel number, PWM cycle, and offset **
    ** Returned value: None **
    uint8_t PWM_Set(uint8_t channelnum, uint32_t on_period, uint32_t off_period)
    ** Function name: PWM_Start **
    ** Descriptions: Enable PWM by setting the PCR, PTCR registers**
    ** parameters: channel number **
    ** Returned value: None ** ******************************************************************************/
    uint8_t PWM_Start(uint8_t channelnum)
    ** Function name: PWM_Stop **
    ** Descriptions: Stop PWM channel **
    uint8_t PWM_Stop(uint8_t channelnum)
    ** End Of pwm.c File
  • I'm sorry, in the preview it shows all the indent& code clearly. I don't why it is happening like this.
  • Hello Eric, Kindly let me know if there is facility to attach files, i'll upload my files. I'm new user & don't much about this GUI.
  • So read the text information you have available directly above the message input box. Don't you notice teh "Place source code ..." part?
    **                            Start Of main.c File
    #include "pwm.h"
    int main (void)
      PWM_Init();
      PWM_Start(PWM4);
      PWM_Start(PWM6);
      while(1)
    **                            Start Of pwm.c File
    #include "type.h"
    #include "pwm.h"
    ** parameters:                  None
      uint8 regVal;
      return;
    ** parameters:                  None
    void PWM_Init(void)
      return;
        switch(channelnum)
                    break;
                    break;
                    break;
      return(channelnum);
        switch(channelnum)
                    break;
                    break;
                    break;
      return(channelnum);
        switch(channelnum)
                    break;
                    break;
                    break;
      return(channelnum);
