I am using P89V51RD2 for my project I have choosen this IC because it have 1K Ram My programme is compiling but while linking I ma getting following errors.
*** ERROR L127: UNRESOLVED EXTERNAL SYMBOL SYMBOL: ask_disp_key_val MODULE: mc_ad1.obj (MC_AD1) *** ERROR L127: UNRESOLVED EXTERNAL SYMBOL SYMBOL: chk_keys MODULE: mc_ad1.obj (MC_AD1) *** ERROR L127: UNRESOLVED EXTERNAL SYMBOL SYMBOL: chk_test_over MODULE: mc_ad1.obj (MC_AD1) *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: ask_disp_key_val MODULE: mc_ad1.obj (MC_AD1) ADDRESS: 10014D3H *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: chk_keys MODULE: mc_ad1.obj (MC_AD1) ADDRESS: 10014D9H *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: chk_test_over MODULE: mc_ad1.obj (MC_AD1) ADDRESS: 10014DCH *** ERROR L127: UNRESOLVED EXTERNAL SYMBOL SYMBOL: MAIN MODULE: C:\KEIL\C51\LIB\C51L.LIB (?C_INIT) *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: MAIN MODULE: C:\KEIL\C51\LIB\C51L.LIB (?C_INIT) ADDRESS: 1000E67H Program Size: data=28.1 xdata=143 const=0 code=6729 Target not created
I am using some of the variables as xdata,I am confused whether this problem is because of xdata? I have done the folloeing changes to startup file also
XDATASTART EQU 0H ; the absolute start-address of XDATA memory XDATALEN EQU 2ffH ; the length of XDATA memory in bytes. AUXR1 DATA 08EH ; add SFR definition STARTUP1: ; enable on-chip xdata RAM ANL AUXR1,#NOT 02H ; AUXR1/Bit 1 (clear to 0 to enable on-chip XRAM)
also my target settings are memory model : large code Rom : Large Use onchip Rom:selected Use onchi XRam :selected Use Multiple DPTR : Selected
Please help me out.
Why large memory model - is it because you want your code to be large and bloated? Why not manually specify what should be separately stored?
Where are your variables. It seems like your project isn't including all source files. Or that you have just said that "somewhere" there will be these symbols but have never given any module the responsibility of owning such symbols. Note declare and define of variables.
symbol names looks like a FUNCTION... if is true... then u might have called these function without including it in the code... or else u had not defined those function before main..
So where is your definition of "ask_disp_key_val"?
That looks wrong. You haven't, by any chance, mis-configuresd the case-insensitive linking option?
