I'm beginner in using Keil µVision 4.0. I have 'LPC1788 Developer's Kit", I want to implement an application that allows me to read a string with the USB port and send it with the RS232 port. Synchronization between reading and writing can it be done without RL-ARM? Any help please ?
I'm not sure that Keil will give for free any USB source code, but you will probably get it from NXP. All µP brands have free libraries and examples to handle USB, SD cards, Ethernet and so on. Your developper kit probably has it already.
Denis
Yes, this is so stupid. There must be a good commercial reason for it, but as long as you stick to NXP chips, you can download a fully functional USB suit for FREE at http://www.lpcware.com. I mean, what those folks are doing is: 1. An insult to our intelligence. 2. Make their highly expensive software suit irrelevant.
No offense intended!
"waafaaa radd" should be identical to "wafi radd" of this post, http://www.keil.com/forum/21611/
The NXP example was already pointed at above thread.
Tsuneo
