Hi all In case there is need to filter the analog input to an analog port what is the best approach ?
Adding external filtering circuits or using dsp libraries in the code?
Thanks Elico
Software allows you to change amount of filtering/bandwidth by reconfiguring your program.
But make sure the voltage reference is well filtered in hardware.
Please explain what software ?
you mean dsp libraries ?
Elico
