//Program to display String on LCD
//Program to interface Serial EEPROM AT24C02 with 8051 microcontroller (AT89C51) #include<reg51.h> #include<intrins.h> //For using [_nop_()]
sbit sda=P1^0; sbit scl=P1^1; sbit led=P0^1; bit ack; sbit led1=P0^2; sbit sav=P0^4; sbit up=P0^5; sbit down=P0^6; sfr lcd_data_pin=0xA0;//p2 port sfr output=0x80;//p0 port sbit rs=P3^1;
sbit en=P3^0; unsigned char reead,write; unsigned int temp,new_value1,new_value,test=0,num=0,i,j; void init() // to initialize the output pins and Timer0 { up=down=1;
TMOD=0x01; TL0=0xf6; TH0=0xFf; IE=0x82; TR0=1; } void delay(unsigned int count) { int i,j; for(i=0;i<count;i++) for(j=0;j<1275;j++); } void lcd_command(unsigned char comm) { lcd_data_pin=comm; en=1; rs=0; delay(1); en=0; } void lcd_data(unsigned char disp) { lcd_data_pin=disp; en=1; rs=1; delay(1); en=0; } lcd_strng(unsigned char *disp) { int x; for(x=0;disp[x]!=0;x++) { lcd_data(disp[x]); } } void lcd_ini() { lcd_command(0x38); // for using 8-bit 2 row LCD delay(5); lcd_command(0x0F); // for display on, cursor blinking delay(5); lcd_command(0x80); delay(5); } void aknowledge() //acknowledge condition { scl=1; _nop_(); _nop_(); scl=0; } void start() //start condition { sda=1; scl=1; _nop_(); //No operation _nop_(); sda=0; scl=0; } void stop() //stop condition { sda=0; scl=1; _nop_(); _nop_(); sda=1; scl=0; } void send_byte(unsigned int value) //send byte serially {
unsigned int i; unsigned int send;
send=value; for(i=0;i<8;i++) { sda=send/128; //extracting MSB send=send<<1; //shiftng left scl=1; _nop_(); _nop_(); scl=0; } ack=sda; //reading acknowledge sda=0; } unsigned char read_byte() //reading from EEPROM serially { unsigned int i; sda=1; reead=0; for(i=0;i<8;i++) { reead=reead<<1; scl=1; _nop_(); _nop_(); if(sda==1) reead++; scl=0; } sda=0; return reead; //Returns 8 bit data here } void save() //save in EEPROM { init(); while(1) { if(up==0&&down==1) //check if up pin is pressed { test++; num=test; new_value=num%10; num=num/10; if(test==9) test=0;
} if(up==1&&down==0) //check if down pin is pressed { test--; num=test; new_value=num%10; num=num/10; if(test==0) test=9;
start(); send_byte(0xA0); //device address aknowledge(); send_byte(0x00); //word address aknowledge(); send_byte(new_value); //send data aknowledge(); stop(); if(ack==0) { /* new_value1=new_value1+48; */ led1=1; delay(100); led1=0; delay(100); lcd_command(0x86); lcd_data(new_value);
} else led1=1; aknowledge(); }
void Read() { start(); send_byte(0xA0); aknowledge(); send_byte(0x00); aknowledge(); start(); send_byte(0xA1); //device address aknowledge(); i=read_byte(); aknowledge(); stop(); if(i==new_value) { led=0; delay(100); led=1; delay(100); write=i+48; lcd_command(0xC6); lcd_data(write); } else led=1;
aknowledge(); }
void main() { lcd_ini();
lcd_strng("Sent :"); lcd_command(0xC0); lcd_strng("Read :"); temp=0; while(1) { save(); Read(); } }
The 'stuff' in your post as shown is NOT (code given below) but a collection of random stuff.
Did you not wonder when you did the preview if anyone could make heads or tail of what you posted?
Is it REALLY that big a deal to follow the instructions above the entry window?
I wonder if there would be a market, if I developed and sold a program that reformatted source code so all (when possible) source lines started with { or }. It does have its charm. But it still isn't a good way to give readability to the block nesting of a program.
I posted: The 'stuff' in your post as shown is NOT (code given below) but a collection of random stuff.
now, wait for the bleeding hearts to feel sorry for you, I do not.
if, after reminded, you can't even take the time to follow the instructions I suggest you buy a broom.
sir. i politely request you should not answer if you can not help. you will put off the kind members with the good answer.
//Program to display String on LCD //Program to interface Serial EEPROM AT24C02 with 8051 microcontroller (AT89C51) #include<reg51.h> #include<intrins.h> //For using [_nop_()] sbit sda=P1^0; sbit scl=P1^1; sbit led=P0^1; bit ack; sbit led1=P0^2; sbit sav=P0^4; sbit up=P0^5; sbit down=P0^6; sfr lcd_data_pin=0xA0;//p2 port sfr output=0x80;//p0 port sbit rs=P3^1; sbit en=P3^0; unsigned char reead,write; unsigned int temp,new_value1,new_value,test=0,num=0,i,j; void init() // to initialize the output pins and Timer0 { up=down=1; TMOD=0x01; TL0=0xf6; TH0=0xFf; IE=0x82; TR0=1; } void delay(unsigned int count) { int i,j; for(i=0;i<count;i++) for(j=0;j<1275;j++); } void lcd_command(unsigned char comm) { lcd_data_pin=comm; en=1; rs=0; delay(1); en=0; } void lcd_data(unsigned char disp) { lcd_data_pin=disp; en=1; rs=1; delay(1); en=0; } lcd_strng(unsigned char *disp) { int x; for(x=0;disp[x]!=0;x++) { lcd_data(disp[x]); } } void lcd_ini() { lcd_command(0x38); // for using 8-bit 2 row LCD delay(5); lcd_command(0x0F); // for display on, cursor blinking delay(5); lcd_command(0x80); delay(5); } void aknowledge() //acknowledge condition { scl=1; _nop_(); _nop_(); scl=0; } void start() //start condition { sda=1; scl=1; _nop_(); //No operation _nop_(); sda=0; scl=0; } void stop() //stop condition { sda=0; scl=1; _nop_(); _nop_(); sda=1; scl=0; } void send_byte(unsigned int value) //send byte serially { unsigned int i; unsigned int send; send=value; for(i=0;i<8;i++) { sda=send/128; //extracting MSB send=send<<1; //shiftng left scl=1; _nop_(); _nop_(); scl=0; } ack=sda; //reading acknowledge sda=0; } unsigned char read_byte() //reading from EEPROM serially { unsigned int i; sda=1; reead=0; for(i=0;i<8;i++) { reead=reead<<1; scl=1; _nop_(); _nop_(); if(sda==1) reead++; scl=0; } sda=0; return reead; //Returns 8 bit data here } void save() //save in EEPROM { init(); while(1) { if(up==0&&down==1) //check if up pin is pressed { test++; num=test; new_value=num%10; num=num/10; if(test==9) test=0; } if(up==1&&down==0) //check if down pin is pressed { test--; num=test; new_value=num%10; num=num/10; if(test==0) test=9; } start(); send_byte(0xA0); //device address aknowledge(); send_byte(0x00); //word address aknowledge(); send_byte(new_value); //send data aknowledge(); stop(); if(ack==0) { /* new_value1=new_value1+48; */ led1=1; delay(100); led1=0; delay(100); lcd_command(0x86); lcd_data(new_value); } else led1=1; aknowledge(); } } void Read() { start(); send_byte(0xA0); aknowledge(); send_byte(0x00); aknowledge(); start(); send_byte(0xA1); //device address aknowledge(); i=read_byte(); aknowledge(); stop(); if(i==new_value) { led=0; delay(100); led=1; delay(100); write=i+48; lcd_command(0xC6); lcd_data(write); } else led=1; aknowledge(); } void main() { lcd_ini(); lcd_strng("Sent :"); lcd_command(0xC0); lcd_strng("Read :"); temp=0; while(1) { save(); Read(); } } If you can not follow instructions, then do not post here The 'stuff' in your post as shown is NOT (code given below) but a collection of random stuff. Did you not wonder when you did the preview if anyone could make heads or tail of what you posted? Is it REALLY that big a deal to follow the instructions above the entry window? Erik
So you take the already destroyed code from the first post, and pasted into a new post - new with tags?
Don't you think that is pointless, since the indentation information have already been lost? What was wrong with copying your source code from the editor, and paste - using proper tags?
Next thing - why did you continue your post with including Erik's text within the "pre" tags?
Do you notice how totally broken this thread looks low, because someone (that would be you) have made a post, where you pasted "source code" that have lines that are several hundred characters long? Looking good? Feeling you have done a proper job? Nothing strange at all visible on the preview?
Now, who do you think will care about looking at your "code" and help you, when you don't care the slightest about the instructions given?
If anyone "put off the kind members with the good answer" it is YOU
you ask people to decipher unformatted scribbles to help you
if you can not help no, I can not help when all you provide is unformatted scribbles
also, your refusal to follow instructions does not exatctly enhance my desire to help you.
sir. very sorry with the bad messages. here is very good. please kindest help now.
//Program to display String on LCD //Program to interface Serial EEPROM AT24C02 with 8051 microcontroller (AT89C51) #include<reg51.h> #include<intrins.h> //For using [_nop_()] sbit sda=P1^0; sbit scl=P1^1; sbit led=P0^1; bit ack; sbit led1=P0^2; sbit sav=P0^4; sbit up=P0^5; sbit down=P0^6; sfr lcd_data_pin=0xA0;//p2 port sfr output=0x80;//p0 port sbit rs=P3^1; sbit en=P3^0; unsigned char reead, write; unsigned int temp, new_value1, new_value, test=0, num=0, i, j; void init() // to initialize the output pins and Timer0 { up=down=1; TMOD=0x01; TL0=0xf6; TH0=0xFf; IE=0x82; TR0=1; } void delay(unsigned int count) { int i, j; for(i=0;i<count;i++) for(j=0;j<1275;j++); } void lcd_command(unsigned char comm) { lcd_data_pin=comm; en=1; rs=0; delay(1); en=0; } void lcd_data(unsigned char disp) { lcd_data_pin=disp; en=1; rs=1; delay(1); en=0; } lcd_strng(unsigned char *disp) { int x; for(x=0;disp[x]!=0;x++) { lcd_data(disp[x]) ; } } void lcd_ini() { lcd_command(0x38); // for using 8-bit 2 row LCD delay(5); lcd_command(0x0F); // for display on, cursor blinking delay(5); lcd_command(0x80); delay(5); } void aknowledge() //acknowledge condition { scl=1; _nop_(); _nop_(); scl=0; } void start() //start condition { sda=1; scl=1; _nop_(); //No operation _nop_(); sda=0; scl=0; } void stop() //stop condition { sda=0; scl=1; _nop_(); _nop_(); sda=1; scl=0; } void send_byte(unsigned int value) //send byte serially { unsigned int i; unsigned int send; send=value; for(i=0;i<8;i++) { sda=send/128; //extracting MSB send=send<<1; //shiftng left scl=1; _nop_(); _nop_(); scl=0; } ack=sda; //reading acknowledge sda=0; } unsigned char read_byte() //reading from EEPROM serially { unsigned int i; sda=1; reead=0; for(i=0;i<8;i++) { reead=reead<<1; scl=1; _nop_(); _nop_(); if(sda==1) reead++; scl=0; } sda=0; return reead; //Returns 8 bit data here } void save() //save in EEPROM { init(); while(1) { if(up==0&&down==1) //check if up pin is pressed { test++; num=test; new_value=num%10; num=num/10; if(test==9) test=0; } if(up==1&&down==0) // check if down pin is pressed { test--; num=test; new_value=num%10; num=num/10; if(test==0) test=9; } start(); send_byte(0xA0); //device address aknowledge(); send_byte(0x00); //word address aknowledge(); send_byte(new_value); //send data aknowledge(); stop(); if(ack==0) { /* new_value1=new_value1+48; */ led1=1; delay(100); led1=0; delay(100); lcd_command(0x86); lcd_data(new_value); } else led1=1; aknowledge(); } } void Read() { start(); send_byte(0xA0); aknowledge(); send_byte(0x00); aknowledge(); start(); send_byte(0xA1); // device address aknowledge(); i=read_byte(); aknowledge(); stop(); if(i==new_value) { led=0; delay(100); led=1; delay(100); write=i +48; lcd_command(0xC6); lcd_data(write); } else led = 1; aknowledge(); } void main() { lcd_ini(); lcd_strng("Sent :") ; lcd_command(0xC0) ; lcd_strng("Read :") ; temp=0 ; while (1) { save() ; Read() ; } }
I wonder why my code looks like:
void main(void) { init(); for (;;) { led_1_on(); delay_ms(500); led_1_off(); delay_ms(500); } }
and your code looks like:
Did you post with tabs? Did you, in that case, see any setting to specify what tab settings your post was expected to have? Didn't you see something strange in the preview, before you pressed Post?
Even more interesting - how come your code looks like:
What web site did you find that recommended having an assign split over three lines?
or:
Since when was it made popular to have the ';' statement termination on a separate line?
Is this how the source code looks in your own editor? Assigns over three lines, and the semicolon sometimes on separate lines?
I don't believe you. Because your latest post contains the following:
Notice that your // comment got split to two lines - the compiler can't accept that "address" word. So you have once more reposted code with already broken indentations, despite me specifically saying that it is a bad idea. You have, once more, posted code that can't be compiled.
here is very good.
You have to be kidding. You've now copy-pasted your code into this forum four times. So you've had four preview opportunities, by minimum. And you still can't be bothered to actually look at the preview to check if it matches what your code is supposed to look like, before you hit "Post"?
Just in case you really don't get it: no, that that is not "very good". That is, at best, a tiny bit less bad than your previous 3 attempts.
Keep in mind that it's you who expects help for free here --- so the least you can do to earn it would be to take care how you present your case. So far you've failed spectacularly at that, four times in a row. Time to get your act together.
sir. you complain. and complain. and complain again. how can it be easier. can you help. you just pretend. yes. YES. can anyone good give help?
And the answer is that whatever we do, we can't even get you to understand that you can't just take the broken code from the first post and repost - that the formatting have been forever lost.
If we can't even get you to understand that you must go all the way back to the code available in the editor, then it isn't likely that we can be able to discuss actual source code with you either. So why should we even try?
sir. you do not understand. sir i ask you not to reply. is there a good person who will answer. my chief always answered well here but he says you always fight his sense and you were jealous because he was so good. i now understand him.
Because you get it wrong. And get it wrong. And get it wrong again.
can you help.
You're doing everything you possibly could to make sure nobody would want to help you. You've been told so a couple of times, and yet you persist behaving like a 5-year-old.
I'm done with you. Good bye.
