hello
i design a board for DP83848 and that 100% work with EasyWeb example but my board not work with http_demo example and other RL example , what is my problem?
Your problem is that you haven't bothered to provide details of what happens. What version of MDK-ARM? Elaborate on what you mean by "my board not work". If you can be bothered to provide more details then may be I can then be bothered to help you.
my MDK-ARM version is 4.50
i designed board for DP83848 and it worked with Easyweb example , i can see easyweb webpage in mozilla firefox and IE and my board pinged with IP 192.168.0.100
my MCU is LPC2368
but not work with http_demo example and not ping with IP 192.168.0.100 and not worked with examples placed in C:\Keil\ARM\Boards\Keil\MCB2300\RL\TCPnet
im sorry for bad English language
how to use http_demo example?
please help me
this is my board include LPC2368 + DP83848 + MMC (memory card) + LCD (16*2)
easyweb example and SD_Memory example very good working i can see page of easyweb in mozilla firefox and IE and see file's on the mmc by SD_Memory example
why example placed in "C:\Keil\ARM\Boards\Keil\MCB2300\RL\TCPnet" address not working , not ping and can not see page of http_demo
please heeeeelp me
pic of my board
www.img4up.com/.../55217002008950544950.jpg
Dear Vahid if you don't have MDK-Professional version , you have some limitations , so first of all press F1 then look at arm development tool to have a concept on this issue , then look at your version of IDE again By the way having multiple posts and requests on these forums is not tolerated Good Luck
Thank you and i am very sorry for multiple posts
F1 not work
pic of my "keil About "
www.img4up.com/.../06507707274459601285.png
My MDK have problem?
Check the PHY settings in init_ethernet(). I also have a board with DP83848 and had to change PHY settings in http_demo. You can find correct settings in other examples. Search for DP83848.
agha vahid mitoni komakam koni ye moshkele kochik daram ba MDK lib haye RL-ARM ham kar nemikone che rahe halli dari?
and in english...?
