Doe Keil IDE support initializing stack space with a constant? For example with a #define. If not, please does someone have ARM Cortex M3/M4 assembler code to do that and where should it be located? For example in startup*.s prior to the branch to main?
Thanks very much for your generous help. It appears to work now as you described with the stack left full of 0xcccccccc.
Does this help:
http://www.keil.com/support/man/docs/armlink/armlink_CHDFHJDJ.htm
Possibly. Thanks for the pointer Andrew. The problem of stack initialisation now seems to be solved. Keil / ARM advise me I can't use a symbolic name directly but,
"If you open a Watch window, you can type 'sp' to 'watch' the stack pointer (r13). Then you can right-click on 'sp' and navigate to 'Add 'sp' to...' -> Memory 1. The stack pointer, is also available in the 'Registers' window."
Hi John,
Why modify the scatter file? It's not easy to put the code in the stack initalisation? The ram is initialized before.
__user_initial_stackheap LDR R0, =Stack_Mem ; Test stack LDR R1, =Stack_Size ; LDR R2, =0xCCCCCCCC ; Fill STR R2, [R0], #4 ; SUBS R1,#4 ; BNE Fill ; LDR R0, = Heap_Mem LDR R1, =(Stack_Mem + Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR ALIGN
thank you for your thread, it helped me a lot.
