SD card FAT damage using RL-ARM
We are using the RL-ARM and FlashFS, but we having some problems. In some cases, the files are corrupted, and some cases the FAT system are physically damaged. We are using the SD card read-only. Our application reads periodically the SD card for print in a TFT display of BMP files and play WAV files. As we not use the SD card for write, we do not care in close files when a power outage happens. We would like to know ASAP which may be causing the problem. Can be a power outage with file open, even being read-only?
