Configure CAN filter to accept all messages
Hi All,
Really need help on this one, any suggestions welcome!....
I'm using the CAN bus example program for MCBSTM32C eval board. It has an STM32F107 chip and I am have issues with the CAN Filter....
Does anyone know how to configure the CAN Filter to accept ALL incoming messages?
Shane
  • Haha, yes that would be great because as a default its supposed to accept all messages, Thats what I am trying to do, however i'm having trouble doing that here. Can't seem to turn it off without blocking everything. which is quite the opposite of what i'm looking for...
  • There supposed to be some functions in ST's OOXX_StdPeriph_Driver Library like:
    void CAN_FilterInit(CAN_FilterInitTypeDef* CAN_FilterInitStruct);
    Maybe see this:
    my.st.com/.../Flat.aspx
    Agree, the documentation is a little confusing. The short answer is that the FilterIDLow
    and FilterIDHigh as well as MaskIDLow and MaskIDHigh don't correspond exactly to the SID/EID.
    The bits need to be shifted depending on the type of ID you are trying to filter. It took me
    several weeks to find the answer on a German website that I used google to translate. Please
    look at my example code below, hopefully it will be clear then.
    In this example four filters are created to receive only SID 123, 124, 125 and 126. They
    don't have to be in order, just happened to be the numbers I picked. For a SID the numbers
    for the Filter/Mask IDs need to be shifted to the left by 5 bits.
    CAN_FilterInitStructure.CAN_FilterNumber = 1;
    CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdList;
    CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_16bit;
    // All filters are shifted left 5 bits
    CAN_FilterInitStructure.CAN_FilterIdHigh = 0x2460;          // 0x123
    CAN_FilterInitStructure.CAN_FilterIdLow = 0x2480;           // 0x124
    CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x24A0;      // 0x125
    CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x24C0;       // 0x126
    CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
    CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
    CAN_FilterInit(&CAN_FilterInitStructure);
  • typedef struct
      uint16_t CAN_FilterIdHigh;         /*!< Specifies the filter identification number (MSBs for a 32-bit
                                                  configuration, first one for a 16-bit configuration).
                                                  This parameter can be a value between 0x0000 and 0xFFFF */
      uint16_t CAN_FilterIdLow;          /*!< Specifies the filter identification number (LSBs for a 32-bit
                                                  configuration, second one for a 16-bit configuration).
      uint16_t CAN_FilterMaskIdHigh;     /*!< Specifies the filter mask number or identification number,
                                                  according to the mode (MSBs for a 32-bit configuration,
      uint16_t CAN_FilterMaskIdLow;      /*!< Specifies the filter mask number or identification number,
                                                  according to the mode (LSBs for a 32-bit configuration,
      uint16_t CAN_FilterFIFOAssignment; /*!< Specifies the FIFO (0 or 1) which will be assigned to the filter.
                                                  This parameter can be a value of @ref CAN_filter_FIFO */
      uint8_t CAN_FilterNumber;          /*!< Specifies the filter which will be initialized. It ranges from 0 to 13. */
      uint8_t CAN_FilterMode;            /*!< Specifies the filter mode to be initialized.
                                                  This parameter can be a value of @ref CAN_filter_mode */
      uint8_t CAN_FilterScale;           /*!< Specifies the filter scale.
                                                  This parameter can be a value of @ref CAN_filter_scale */
      FunctionalState CAN_FilterActivation; /*!< Enable or disable the filter.
                                                  This parameter can be set either to ENABLE or DISABLE. */
    } CAN_FilterInitTypeDef;
  • Thank you for your reply John, I'm just getting back to this now so I'll review this and let you know how it goes! Much Appreciated.
