Hello, I have already post a thread regarding simulation of I2C in Keil, and I solve it with your help from this forum. Now I would like to test my I2C code, I am using LPC2148 and trying to write and read EEPROM. I have read all the samples and I got an online sample which I get some idea of it and wrote my code, but I have these questions: since I can't do simulation with it, I am trying to send the read data from EEPROM to LEDs to see what is the data, but when I want write data to EEPROM, I am not sure how to assign its address?I know the slave address, but the address which I want write to it. please anyone has an Idea thanks Neda
Hi Neda,
Are you using Keil's library?
Also please specify the eeprom chip that you want to write it.
What is your I2C bus speed? Is it low enough to test with LEDs?!
http://automasys.wordpress.com automasys.persiangig.com
Hi, Thanks for your reply. the EEPROM is:CAT1025-30 with 400khz I2Cbus. I am using Keil's library? for what? I am using lpc2148, but the header file, I define it.
