Hi, how can i define device (from Option dialog) inside .c program as predefined macro ?
thanks
why do you want to do it?
I want make some depends from CPU type for example
#if CPU_TYPE == STM32F205RE #define ... #elif CPY_TYPE == STM32F205RG #define ... #endif
I think that it is a major omission that uVision does not make any of the GUI settings available to the code; eg, by command-line defines, or an auto-generated header.
It has been noted here many times before.
I had a quick look, and I can't see anything to suggest that it's been added recently.
For the specific case of the CPU_TYPE, you could look at: http://www.keil.com/support/man/docs/uv4/uv4_ut_keysequence.htm
Maybe also look at: http://www.keil.com/support/man/docs/uv4/uv4_ut_configwizard.htm
I think that it is a major omission ...
Might be useful (though exactly how useful is debatable), but really don't think it could be classed as a major omission.
Helpfully if Keil add device name as define variable - for example as __DEVICE_TYPE
