Trouble with linkers lx51 and bl51
I have recently downloaded quicksense studios for use in a capacitive sensing application. After using their utility to generate a lot of the needed source code, I decided to try and assemble and build the project using c51. I used the ax51 assembler, the cx51 compiler, and the lx51 linker. Eventually I managed to get the filed to assemble and compile, generating the needed object files. When I attempt to link them however, I keep getting this error:
@C:\Users\_I_\Documents\tc\test3\cyglink.txt "C:\Users\_I_\Documents\tc\test3\QS_Config.obj",
"C:\Users\_I_\Documents\tc\test3\QS_DeviceInit.obj",
"C:\Users\_I_\Documents\tc\test3\QS_Main.obj",
"C:\Users\_I_\Documents\tc\test3\QS_Threshold_Cal.obj",
"C:\Users\_I_\Documents\tc\test3\QS_F99xRoutines.obj",
"C:\Users\_I_\Documents\tc\test3\QS_Baselining.obj",
"C:\Users\_I_\Documents\tc\test3\QS_Core.obj",
"C:\Users\_I_\Documents\tc\test3\QS_Events.obj",
"C:\Users\_I_\Documents\tc\test3\QS_Exp_Averager.obj",
"C:\Users\_I_\Documents\tc\test3\QS_Groups.obj",
"C:\Users\_I_\Documents\tc\test3\QS_Memory.obj",
"C:\Users\_I_\Documents\tc\test3\QS_nDPad.obj",
"C:\Users\_I_\Documents\tc\test3\QS_Timing.obj",
"C:\Users\_I_\Documents\tc\test3\QSCI_Memory.obj",
"C:\Users\_I_\Documents\tc\test3\QSCI_Memory_lite.obj",
"C:\Users\_I_\Documents\tc\test3\QSCI_Core_Lite.obj",
"C:\Users\_I_\Documents\tc\test3\QSCI_UARTRoutines_lite.obj"  TO "C:\Users\_I_\Documents\tc\test3\test3" RS(256) PL(68) PW(78) CODE(0, ?CO?QS_CONFIG(0x100))
*** ERROR L204: INVALID KEYWORD
    POS: 1054
    Routines_lite.obj TO C:\Users\_I_\Documents\tc\test3\test3 RS
I do not understand why it is registering as an invalid keyword. I decided to try using bl51 instead. I got a different error message:
*** FATAL ERROR L218: NOT AN OBJECT FILE
    FILE: C:\Users\_I_\Documents\tc\test3\QS_Config.obj
However, when I go and check this directory, all the corresponding object files have been generated.
what am I missing? Any and all help is appreciated.
