Keil and Eclipse
I wanted to know if someone has successfully integrated the Keil within Eclipse.
- I have installed plugins of the Keil into an Eclipse Indigo and apparently works. Sometimes I don't run the Build All in a first time and I have to make it several times ... Does anyone know why?
- I have not been able to use the information for compilation errors to skip to the file, and to the line where the error is. How is it necessary to do it?
- Are someone set up a compiler of RealView compidador as external? Armcc - ... .
- How can I do to work the Browse información or indexer in Eclipse?
- Where can I find more information about how do the maximize integration of the Keil with Eclipse?
It would be of great utility their advices.
Thank You
