i m a M.Sc Electronics Student and now i have been told to interface the keypad on the Dev kit the board is Called Spirit II from Oasis, it has a LPC2148. the keypad is a matrix keypad. now whats done here is, its connected to a resistor array and the resistor array has a Vcc given to it. so. when i make the rows as input and columns as output the rows become high by default if the columns are made input they become high by default
Algorithm Set Keypad pins to output initially clear the port so now, i make rows high read columns i mae columns high read rows, and the result left shift answer by 2 send value to main Take the Value and Switch
CODE:
#include<lpc21xx.h> #include<lcd.h> #include<oasis_key.h> unsigned key; char k_value; int main(void) { PINSEL2=0x00000000; //mode of operation PINSEL0=0x00000000; //mode of operation IODIR0 |= 0x0000183C; make_out_lcd_port(); lcd_init(); clr_lcd_port();delay(); lcd_cmd(0x00800000);delay();clr_lcd_port(); lcd_cmd(0x00010000);delay();clr_lcd_port(); lcd_data('X');delay();clr_lcd_port(); while(1) { key=key_read(); switch(key) { case 0x81 : k_value='1';break; case 0x82 : k_value='2';break; case 0x84 : k_value='3';break; case 0x88 : k_value='A';break; case 0x41 : k_value='4';break; case 0x42 : k_value='5';break; case 0x44 : k_value='6';break; case 0x48 : k_value='B';break; case 0x21 : k_value='7';break; case 0x22 : k_value='8';break; case 0x24 : k_value='9';break; case 0x28 : k_value='C';break; case 0x11 : k_value='*';break; case 0x12 : k_value='0';break; case 0x14 : k_value='#';break; case 0x18 : k_value='D';break; case 0x00 : k_value='N';break; } lcd_cmd(0x00C00000);delay();clr_lcd_port(); lcd_data(k_value);delay();clr_lcd_port(); } } //LCD MOdule #include<lpc21xx.h> int i; #define lcd_rs 0x00000800 //defines rs pin #define lcd_en 0x00001000 //defines en pin #define lcd_port 0x00FF0000 //defines lcd port #define make_out_en_rs() IODIR0 |= (lcd_rs | lcd_en) //makes en,rs output #define make_out_lcd_port() IODIR1 |= lcd_port //makes lcd port out #define clr_lcd_port() IOCLR1 |= lcd_port //clears lcd port #define lcd_rs_set() IOSET0 |= lcd_rs #define lcd_en_set() IOSET0 |= lcd_en #define lcd_rs_clr() IOCLR0 |= lcd_rs #define lcd_en_clr() IOCLR0 |= lcd_en void delay() { for(i=0;i<40000;i++); } void lcd_cmd(unsigned int value) { IODIR0 |= 0x0000183C; lcd_rs_clr(); IOSET1=value; lcd_en_set(); lcd_en_clr(); delay(); } void lcd_data(unsigned char val) { unsigned result; IODIR0 |= 0x0000183C; result=val; for(i=0;i<16;i++) {result=result<<1;} lcd_rs_set(); IOSET1=result; lcd_en_set(); lcd_en_clr(); delay(); } void char_string(char a) { lcd_data(a); clr_lcd_port();delay(); } void lcd_init() { lcd_cmd(0x00380000);delay(); clr_lcd_port(); lcd_cmd(0x000C0000);delay(); clr_lcd_port(); } //keypad library void debounce(void); int keyread (void); unsigned key_read(void) { unsigned rows,columns,result; IODIR0=0x000003FC; IOCLR0=0x00000FFF; IOSET0=0x000003C0; columns=IOPIN0; IOCLR0=0x00000FFF; IOSET0=0x0000003C; rows=IOPIN0; debounce(); result=rows & columns; result=result>>2; result=result & 0x000000FF; return(result); } void debounce(void) { unsigned int j; for (j=0;j<200000;j++) { } }
Pin 0.2 ROW1 Pin 0.3 ROW2 Pin 0.4 ROW3 Pin 0.5 ROW4 Pin 0.6 COl1 Pin 0.7 COl2 Pin 0.8 COl3 Pin 0.9 COl4
Pin 0.11 RS Pin 0.12 EN
Code Is Working, Detecting Keys Fine, i m happy
Present Problem : Keys are arranged in this fashion
1 2 3 A 4 5 6 B 7 8 9 C * 0 # D
Keys 1,2,4,5,7,8,*,0 are not Getting Detected zzz
Anyone With Any Suggestions Pls Comment, Any Help will do
high by default make rows high mae columns high
everything will always be high, nothing will ever be low
i mean clear the port 1. make rows high ( columns low) read columns 2. make columns high (rows low) read rows
i didnt use it as in input port because by default it goes high so when i use it as an output port i can manipulate the pins.
IOPIN0 register reports current value of the pin irrespective of direction i noticed so depending on what key is pressed its giving me that unique value.
its working for a section of keys as i said just the 1st section is not getting detected
