Problem while accessing external RAM.
I am using AT89S52 MCU as a target device.
The idea here is to access (Read/Write) internal registers of an peripheral IC DS21554 from Dallas. I will be accessing this registers as external RAM memory locations.
Now, i checked whether the pins RD(P3.7) & WR(P3.6) are asserted (goes low) automatically using Logic Analyzer while executing the following code:
volatile unsigned char xdata ptr _at_ 0x4000;
void main(void)
{ unsigned char charVal; ptr = 0x55; // Write. charVal = ptr; // Read.
But, it didn't happen the way expected.
Since, in this code a we are trying to read and write to external data memory location, ideally RD(P3.7) and WR(P3.6) should go low. So, is there anything wrong with the code i am using and if it is then please suggest the right way to do so.
  • The first thing that's wrong with it is that you didn't read the instructions for posting source code on this forum.
    Look at this picture: www.danlhenry.com/.../keil_code.png - it shows you that the instructions are very simple, and clearly stated.
    If you can miss simple, clearly stated instructions here, then there must be a high likelihood that you have also missed something in the AT89S52 Datasheet - so you need to go back and study the Datasheet carefully.
    Pay particular attention to how the chip decides whether to access its on-chip XDATA space, or off-chip...
    Also check the Atmel site for other supporting information - application notes, examples, etc, ...
