I have the following inline assembly for GCC that I want to port to Keil's compiler:
#define EnterCritical() \ register uint32_t primask__; \ __ASM volatile ("mrs %0, primask" : "=r" (primask__) : /* no inputs */ ); \ __disable_irq() #define ExitCritical() \ __ASM volatile ("msr primask, %0" : "=r" (primask__) : /* no inputs */ )
I have attempted to port it by doing the following:
__forceinline static __ASM uint32_t __EnterCritical(void) { mrs r0, primask cpsid i } __forceinline static __ASM void __ExitCritical(uint32_t prm) { msr primask, r0 } #define EnterCritical() register uint32_t primask__ = __EnterCritical(); #define ExitCritical() __ExitCritical(primask__);
However, the disassembly shows that __EnterCritical and __ExitCritical are not being inlined, they are being called with the BL instruction. How can I duplicate the GCC inline assembly?
