Restarting DMA xfer on USART RXNE event.
Keil ARM Cortex-M3 Forum,
l can restart the DMA engine by set into circular dma mode, and the sem give and take works between the IRQ and the main task. However when I try use normal dma mode as opposed the cir que. I can't seem to restart the DMA.
task void
mainTask() {
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
memset(RxBuffer3,0,(DMA_TX_BUF_SIZE * MAX_Q_SLOTS) - 1);
 * Config RCC registers for USART3 DMA
/* DMA clock enable */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
/* Enable GPIO clock */
RCC_APB2PeriphClockCmd(USART3_GPIO_CLK | RCC_APB2Periph_AFIO, ENABLE);
/* Enable USART3 Clock */
RCC_APB1PeriphClockCmd(USART3_CLK, ENABLE);
//Enable DMA1 channel3 IRQ Channel. This channel is
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel3_IRQn; //USART 3 RX
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
// Config GPIO registers for USART3 DMA
// Enable the USART3 Pins Software Remapping */
GPIO_PinRemapConfig(GPIO_PartialRemap_USART3, ENABLE);
/* Configure USART3 Rx as input floating */
GPIO_InitStructure.GPIO_Pin = USART3_RxPin;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(USART3_GPIO, &GPIO_InitStructure);
/* Configure USART3 Tx as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = USART3_TxPin;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
// Config DMA engine for TX and RX on USART3
init_dma_channel_params(DMA_CHANNEL_USART_3_RX,&g_dma_usart3_rx_init_info);
config_dma_channel(DMA_CHANNEL_USART_3_RX,&g_dma_usart3_rx_init_info);
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART3, &USART_InitStructure);
/* Enable USARTz DMA Rx and TX request */
USART_DMACmd(USART3, USART_DMAReq_Rx | USART_DMAReq_Tx, ENABLE);
/* Setup the DMA semaphores to the empty state */
init_dma_sems();
/* Enable DMA1 Channel3 Transfer Complete interrupt */
DMA_ITConfig(DMA1_Channel3, DMA_IT_TC, ENABLE);
/* Get Current Data Counter value before transfer begins */
CurrDataCounterBegin3 = DMA_GetCurrDataCounter(DMA1_Channel3);
/* Enable the engine for recieving UIC messages */
DMA_Cmd(USART3_Rx_DMA_Channel, ENABLE);
/* Enable the USART3 */
USART_Cmd(USART3, ENABLE);
0
