Hi, While compiling my program I've faced with this warning:
linking... *** WARNING L5: SECTION LOCATED OUTSIDE CLASS AREA SECTION: ?SD0?MAINTASK CLASS: SDATA0 Program Size: data=96233(near=12643) const=17312(near=174) code=344442
I solved this warning by expanding the SDATA section (as highlighted below). But this way after downloading the program in device, it doesn't work, and the code sticks somewhere.
I have two external memory as follows:
ROM -> Start: 0x10000 Size:0x100000 RAM -> Start: 0x110000 Size:0x80000
Default memory layout is:
ICODE (0x10000-0x10FFFF), FCODE (0x10000-0x10FFFF), FCONST (0x10000-0x10FFFF), HCONST (0x10000-0x10FFFF), XCONST (0x10000-0x10FFFF), NCONST (0x10000-0x13FFF), NDATA (0x110000-0x113FFF), NDATA0 (0x110000-0x113FFF), SDATA (0xE000-0xE7FF, 0xF600-0xFDFF), SDATA0 (0xE000-0xE7FF, 0xF600-0xFDFF), IDATA (0xF600-0xFDFF), IDATA0 (0xF600-0xFDFF), FDATA (0x110000-0x18FFFF), FDATA0 (0x110000-0x18FFFF), HDATA (0x110000-0x18FFFF), HDATA0 (0x110000-0x18FFFF), XDATA (0x110000-0x18FFFF), XDATA0 (0x110000-0x18FFFF)
and I changed it to this
ICODE (0x10000-0x10FFFF), FCODE (0x10000-0x10FFFF), FCONST (0x10000-0x10FFFF), HCONST (0x10000-0x10FFFF), XCONST (0x10000-0x10FFFF), NCONST (0x10000-0x13FFF), NDATA (0x110000-0x113FFF), NDATA0 (0x110000-0x113FFF), SDATA (0xE000-0xEAFF, 0xF600-0xFDFF), SDATA0 (0xE000-0xEAFF, 0xF600-0xFDFF), IDATA (0xF600-0xFDFF), IDATA0 (0xF600-0xFDFF), FDATA (0x110000-0x18FFFF), FDATA0 (0x110000-0x18FFFF), HDATA (0x110000-0x18FFFF), HDATA0 (0x110000-0x18FFFF), XDATA (0x110000-0x18FFFF), XDATA0 (0x110000-0x18FFFF)
It seems that I can't change the memory layout like this. What should I do to resolve this problem. Or actually how should I change the memory layout?
Note that When I delete some of the variables, with default memory layout, the program works fine.
