USB HID reports longer than 64 bytes on lpc1768
I'm on the board MCB1700.
I took the example of Keil (C:\Keil\ARM\Boards\Keil\MCB1700\RL\USB\RTX_HID)
I modify the code following the instructions in this forum : http://www.keil.com/forum/17770/
It works well with 64 bytes, but when I change to 300 bytes, It does not work.
The device is not well recognized.
This is what I changed.
usbdesc.c
/* Endpoint, HID Interrupt In */
  USB_ENDPOINT_DESC_SIZE,            /* bLength */
  USB_ENDPOINT_DESCRIPTOR_TYPE,      /* bDescriptorType */
  USB_ENDPOINT_IN(1),                /* bEndpointAddress */
  USB_ENDPOINT_TYPE_INTERRUPT,       /* bmAttributes */
  WBVAL(0x012c),                     /* wMaxPacketSize */<----- 300 bytes
  0x01,          /* 1ms */          /* bInterval */
        /* Endpoint, HID Interrupt Out */        // rajout EP OUT
  USB_ENDPOINT_OUT(1),                /* bEndpointAddress */
hid.h
#define HID_ReportCountS(x)      0x96,(x&0xFF),((x>>8)&0xFF) //add to the table HID_ReportDescriptor[]
hiduser.h
/* HID report size (count) */
#define HID_INPUT_REPORT_BYTES       300              /* size of report in Bytes */
#define HID_OUTPUT_REPORT_BYTES      300              /* size of report in Bytes */
#define HID_FEATURE_REPORT_BYTES     300              /* size of report in Bytes */
Here is the configuration on the PC side using the software USB View.
Device Descriptor:
bcdUSB:             0x0200
bDeviceClass:         0x00
bDeviceSubClass:      0x00
bDeviceProtocol:      0x00
bMaxPacketSize0:      0x40 (64)
idVendor:           0xC251
idProduct:          0x2201
bcdDevice:          0x0100
iManufacturer:        0x01
0x0409: "Keil Software"
iProduct:             0x02
0x0409: "Keil MCB1700 HID"
iSerialNumber:        0x03
0x0409: "0001A0000000"
bNumConfigurations:   0x01
ConnectionStatus: DeviceConnected
Current Config Value: 0x00
Device Bus Speed:     Full
Device Address:       0x02
Open Pipes:              0
Configuration Descriptor:
wTotalLength:       0x0029
bNumInterfaces:       0x01
bConfigurationValue:  0x01
iConfiguration:       0x00
bmAttributes:         0x80 (Bus Powered )
MaxPower:             0x32 (100 Ma)
Interface Descriptor:
bInterfaceNumber:     0x00
bAlternateSetting:    0x00
bNumEndpoints:        0x02
bInterfaceClass:      0x03 (HID)
bInterfaceSubClass:   0x00
bInterfaceProtocol:   0x00
iInterface:           0x04
0x0409: "HID"
HID Descriptor:
bcdHID:             0x0100
bCountryCode:         0x00
bNumDescriptors:      0x01
bDescriptorType:      0x22
wDescriptorLength:  0x0024
Endpoint Descriptor:
bEndpointAddress:     0x81  IN
Transfer Type:   Interrupt
wMaxPacketSize:     0x012C (300)
bInterval:            0x01
bEndpointAddress:     0x01  OUT
bInterval:            0x01
And with the software USBlyser, i don't see the "Interface 0 HID Report Descriptor".
(I have an exclamation-mark on the USB)
I searched the forum but I found nothing for my problem.
if someone has an idea? thank you.
  • HID device can exchange reports greater than 64 bytes.
    But wMaxPacketSize of the interrupt endpoints can't go over 64 bytes (on Full-Speed) - It's the reason why your device fails enumeration.
    On the firmware, such a large report is split into 64 bytes packets,
    and the packets are exchanged over the interrupt endpoints.
    Host application sends / receives such large report in a single write/read call.
    On the PC, host controller splits / gather packets.
    For the details, see this topic. This topic is also applied to lpc1768, without any change.
    USB HID reports longer than 64 bytes on lpc2141
    http://www.keil.com/forum/12679/
    Tsuneo
  • Hi Tsuneo,
    thank you, I realized my mistake.
    Now, I fixed my wMaxPacketSize IN and OUT at 0x0040 (64bytes) and my PC fully recognize my USB-HID.
    I come now to send the PC to the LPC more than 64 bytes, but not the LPC to the PC.
    Here is my example :
    __task void USB_EndPoint1 (void) {
    U16 evt;
    static U32 report_size=0;
    for (;;) {
      os_evt_wait_or(0xFFFF, 0xFFFF);         /* Wait for an Event */
      evt = os_evt_get();                     /* Get Event Flags */
      if (evt & USB_EVT_OUT) {                                 // OUT EP1 interrupt comes
        report_size += USB_ReadEP( HID_EP_OUT, &OutReport[report_size] );     //   read out the output report
        if(report_size==HID_OUTPUT_REPORT_BYTES)
            memcpy(InReport, OutReport, report_size );
            report_size=0;
            os_sem_wait( USB_IN_EP1_Semaphore, 0xffff );           //   wait until IN EP is available
            USB_WriteEP( HID_EP_IN, InReport, HID_INPUT_REPORT_BYTES ); //   pass it to the endpoint
      if (evt & USB_EVT_IN)        // IN EP1 interrupt comes
        os_sem_send( USB_IN_EP1_Semaphore );                   //   IN EP1 is free
    When I look with USBlyzer, it warns me of bytes that will come but I do not see them.
    Reception is not acknowledged.
    I understand that the packets are mince by 64.
    But the function USB_WriteEP() does not cut in blocks of 64?
    do support the function more than 64 bytes?
    do I change it?
    U32 USB_WriteEP (U32 EPNum, U8 *pData, U32 cnt) {
      U32 n;
      os_mut_wait(USB_HW_Mutex, 0xFFFF);
      LPC_USB->USBCtrl = ((EPNum & 0x0F) << 2) | CTRL_WR_EN;
      LPC_USB->USBTxPLen = cnt;
      for (n = 0; n < (cnt + 3) / 4; n++) {
        LPC_USB->USBTxData = *((__packed U32 *)pData);
        pData += 4;
      LPC_USB->USBCtrl = 0;
      WrCmdEP(EPNum, CMD_VALID_BUF);
      os_mut_release(USB_HW_Mutex);
      return (cnt);
  • > But the function USB_WriteEP() does not cut in blocks of 64?
    No it doesn't.
    USB_WriteEP() sends a packet, up to 64 bytes (wMaxPacketSize).
    Like the OUT endpoint, your firmware has to split the report into 64 bytes packets.
    Each packets is passed to USB_WriteEP() in USB_EVT_IN
    U16 evt;
    static U32 out_report_size = 0;
    static U32 in_report_size = 0;
           U32 in_index;
           U32 in_send_size;
    for (;;) {
        out_report_size += USB_ReadEP( HID_EP_OUT, &OutReport[out_report_size] );
        if(out_report_size == HID_OUTPUT_REPORT_BYTES)
                                                      // now, IN EP and its context is available
            memcpy(InReport, OutReport, out_report_size );
            in_report_size = out_report_size;
            in_index = 0;
                                                      // force EP1 IN interrupt manually
            LPC_USB->USBEpIntSet = 1 << EPAdr(HID_EP_IN);
      if (evt&USB_EVT_IN) {                            // IN EP1 interrupt comes
        if ( in_report_size == 0 ) {                   // this interrupt is caused by the last packet?
        } else {                                       // there remains bytes to be sent
          in_send_size = HID_IN_EP_MAXPACKET_SIZE;     // pick up a packet size
          if ( in_report_size < HID_IN_EP_MAXPACKET_SIZE ) {
            in_send_size = in_report_size;
          USB_WriteEP( HID_EP_IN, InReport + in_index, in_send_size );
          in_report_size -= in_send_size;              // move counter and index by sent size
          in_index       += in_send_size;
    Tsuneo
  • Aha, missed on this line
    static U32 in_index;
    Tsuneo
  • hi tsuneo,
    thank for you help.
    If I fixed my reports a 64 and I send several packets, there is no real difference ?
