LPC2400.s startup bug?
I was looking at the lpc2400.s startup code and I saw that the offset values for EMC_DYN_CFG1_OFS until EMC_DYN_RASCAS3_OFS are wrong at my opinion.
you can see the registers like EMCDynamicConfig0 in the datasheet.
it is:
EMC_DYN_CFG0_OFS EQU 0x100
EMC_DYN_RASCAS0_OFS EQU 0x104
EMC_DYN_CFG1_OFS EQU 0x140
EMC_DYN_RASCAS1_OFS EQU 0x144
EMC_DYN_CFG2_OFS EQU 0x160
EMC_DYN_RASCAS2_OFS EQU 0x164
EMC_DYN_CFG3_OFS EQU 0x180
EMC_DYN_RASCAS3_OFS EQU 0x184
it must be:
EMC_DYN_CFG1_OFS EQU 0x120
EMC_DYN_RASCAS1_OFS EQU 0x124
EMC_DYN_CFG2_OFS EQU 0x140
EMC_DYN_RASCAS2_OFS EQU 0x144
EMC_DYN_CFG3_OFS EQU 0x160
EMC_DYN_RASCAS3_OFS EQU 0x164
this startup file is provided by KEIL with each example of MCB2400.
I also saw that the offset value EMC_STA_EXT_W_OFS is wrong, but this is corrected in the new KEIL (I have mdk 4.11)
