Hi
When I tried to load one of the example provided by Actel into smartfusion board a window popped up saying "Flash download failed - CortexM3"
Following is the Build log
Program Size: Code=8110 RO-data=1522 RW-data=164 ZI-data=4988 ".\obj\Voltage_Monitor_MSS_MSS_CM3_0_app.axf" - 0 Error(s), 3 Warning(s). Load "D:\\Deepthi\\satish_D\\POT_LED_Libero_Keil\\POT_LED_Libero_Keil\\Voltage_Monitor\\Keil\\obj\\Voltage_Monitor_MSS_MSS_CM3_0_app.AXF" No Algorithm found for: 20000000H - 20002643H Erase skipped!
I even added a suitable flash device in the Programming algorith tab under settings in utilities. But still the problem continues. Please suggest me a solution.
Options For Target -> Utilities -> (Ulink) Settings
Did you add a / the correct Flash Algo there?
BR, /th.
