Hello, maibe someone tryed to connect LF antenna to mcb1700 board ? (lpc1768) i need some help, i have 125khz antenna but do not know how to connect it to the board.
What kind of consultant are you, you fool :-0 He must stick it in a RS-485 connector!
thats good , i have one tool with antena connectin via micro usb . 4 pins . white and red wire for LF antenna and black and green for HF antenna ... i just wanted to check , can i connect via usb or not :) thanks for compliment "fool" :)
Actually, I was addressing "Frustrated Consultant" - not you.
A poor one who only ever seems to give free advice :(
You can connect to it, but the more important question you should ask is whether it's likely to work.
So now it's gone from being just one antenna to two!!
Indeed!!
Might this be an antenna for RFID? In that case, you may also need a 125kHz RF module for producing that 125kHz signal to the antenna.
Or might it be that your "antenna" is a complete module+antenna? In that case, this module must have some interface. But only you would know what module it is, so only you (or the manufacturer) would know if it interfaces on RS-232, USB or is expected to be connected to raw digital signals. And in the last case, if these signals are intended to use 3.3V logic or 5V logic or maybe even something else.
Or an RF module for receiving that 125kHz signal from the antenna;
Or an RF module for both transmitting and receiving - commonly known as a transceiver.
