I have tried to run USB Host MSD_File example on the MCB 1700 board (with LPC 1768). I have built and downloadded the code to the board successsfully. But when I run in debug mode and launch the UART window. I can not input inside the serial window. ie, when I type something on keyboard, nothing show on the window.
Then How to test the example?
I have same issue when I look at this link:
http://www.keil.com/support/man/docs/rlarm/rlarm_fs_ex_msd.htm
I have tried 2 ways:
1. run the application with USB stick plug into the board USB host. then use hyperterminal to send command like TYPE ... in the document. But not work
2. In debug mode, using serial window (UART1) type command like TYPE ... as document said and not work.
No one know how to run the example? How about Keil's support?
What is the USB host type on the MCB1700 board?
I see the document said it is Micro AB. But It looks to me it is type A. Can anyone confirm that?
I am using the regular USB stick plug into the USB host on the board and hyperterminal said " Driver not connected, please connect it ..."
