hi , i would like to know how to interface AD590 temp sensor with arm, i am not able to calibrate it properly
www.8052.com/.../160143
How to interface to an arm? You pick up the AD590, then press it hard enough against the skin. Preferably apply some grease to reduce the temperature coefficient.
Oh. You mean interfacing with an ARM processor? Wouldn't that depend very, very, very much on which specific ARM processor? You do think it's the ARM core you interface with, and not the processor-specific peripherial functionality?
You have located the datasheet/user manual for yuor processor? We most definitely have not - we don't even know which processor so are totally unable to.
Yes and no!
As far as the AD590 is concerned, it is entirely irrelevant. The AD590 neither knows nor cares what it is connected to - all that matters is that it follwos the requirements stated in the AD590 Datasheet.
Should, of course, be "follows"
please read the question carefully then answer it...thank u
The answer has already been given!
It is here: www.8052.com/.../160143
Please read the answers carefully, then surprise your self and start to think about what was said in the answers.
i think it is better to share your knowledge (if u have) than sledging....
Knowledge or code? Oh, by the way: it will not, most likely, work without changes. So sit down, read the link (yes - do read and understand it) and get on with it.
please read reply no 2
I have shared my knowledge - here: www.8052.com/.../160143
If you have followed that process, and you are now stuck, then explain what you've done and ask some specific questions.
If you want your work done for you, then you will have to pay for that.
This is reply No 2 in this thread:
It states that you need to provide more information before any answer is possible!
Have you studied the Datasheet for whatever ARM processor it is that you're using?
tell for lpc2138
So what do you do if you have a current generator and want to measure the generated current?
Knowing that it's the LPC2138 that is used, you would then also know what peripherial hardware that processor contains. See any suitable hardware for the task? What is the full range currents you may get from the sensor? What is the full range xx that the processor can measure? What would then a suitable method be for maintaining as good a resolution as possible?
Have you read the Datasheet for the LPC2138?
As it's an NXP part, you will also have to study the User Manual
