Hi, i am using Keil uVision 4 for my own embedded study. I am using a LPC2148 on-card controller and i have some source codes of peripherals supported by sensor-card producer which is sparkfun. I am having trouble in compiling C++ codes such as :
Build target 'imu_v1' compiling deneme.cpp... --- Error: failed to execute 'C:\Documents and Settings\All Users\Documents\ultimate IMU\github.com\Ultimate-IMU\Library\ArmCC' Target not created
Can anyone help ? Thank you in advance.
That's not the usual install path used by the Keil tools - are you using Keil tools?
Pathnames with spaces are always best avoided...
Hi Andy, I use MDK4 uVison 4. I have solved the problem by constructing a new project file and transfering all sources. Thank you for your help:)
