RTX Mutex Functions ThreadSafe?
Hi everyone
We use the RL-Arm RTX V4.20 with Cortex-M3 (STM32F101VC).
In my software I use a Mutex to make the access to a shared Buffer thread safe. This buffer is accessed from two different Tasks. The software is working well sometimes a day, sometimes only 1 hour. After this the LowPrio Task is in Wait for Mutex state forever, the High prio task is running well.
I checked the source code of the RL-Arm rt_Mutex.c and found no thread safety functionality for the mutex functions. My question is now, why there is no task_lock while accessing the Mutex Data? If a task switch is generated while execution is in rt_mut_wait or rt_mut_release, the Mutex Data could be corrupt. Is there an implementation mistake on my side?
Example Code:
Tick every 1ms, Robinout every 5ms.
// High prio task
__task void task1 (void)
  for(;;)
    os_evt_wait_or(0xffff, 0xffff)
    os_mut_wait( Mutex, 0xffff);
    // using the buffer
    os_mut_release(Mutex);
// Low prio task
__task void task2 (void)
  for(;;)
    // using the buffer
    // doing some other stuff
    os_dly_wait (100);
// Timer Interrupt generated by a communication protocol
void TIM1_UP_IRQHandler( void )
  isr_evt_set( flag, TASK1_ID );
  • Are you using interrupt priority grouping?
    The priority grouping is not supported in MDK4.20 yet, but will be in the next MDK release.
    www.keil.com/.../rlarm_ar_hints_cortex.htm
  • You are right, I use the priority grouping as follows:
      NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        /* Enable the USART1 Interrupt */
      NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
      NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
      NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
      NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
      NVIC_Init(&NVIC_InitStructure);
      /* Enable the TIM1 UP Interrupt */
      NVIC_InitStructure.NVIC_IRQChannel = TIM1_UP_IRQn;
    Docu: The lowest two pre-emption priorities are reserved for RTX kernel, all remaining pre-emption priorities are available to use in your application.
    I will put now the NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2
    Could this solve my bug with the hanging task2?
    What I don't understand is, what does lock the task switch while executing the mutex functions? I know the RTX handles this issue. But how?
