I am trying to interface ADC-cs5463 with P89v51rd2 micro controller using "bit banging SPI" code but not getting any result.
I am using below code if any one can see the code and if i am making some mistake or doing wrong than reply me.
Please help me to find the problem.
#include "p89v51rx2.h" #include <stdlib.h> #include <stdio.h> #include <string.h> #include <math.h>
//-----------------------------------ADC CS5463------------------ sbit nreset = P3^3; //RESET PIN OF CS5463 sbit cs = P3^4; //CHIP SELECT OF CS5463 sbit sclk = P3^7; //SERIAL CLOCK sbit sdo = P3^6; //SERIAL DATA OUT sbit sdi = P3^5; //SERIAL DATA IN
unsigned char sec_cnt=0; unsigned long longVar=0;
unsigned char mdatahigh; unsigned char mdatamid; unsigned char mdatalow;
//--------------------- Functions Related to CS5463 --------------------------------- void init_cs5463(void);
void main(void) {
init_cs5463();//initiallises the cs to function as per our requirements
void init_cs5463(void) {
write_to_reg(0x40,PCB,0x80,0x61); //write to config register(0x40)
cs=0;
transfer_byte(0xe8); // start continuous conversions..
cs=1;
//Here is my while loop and try to read the CS5463 register and disply it,but not able //to get any response from the it.
longVar = 0;
while(1)
read_a_reg(0x40,(unsigned char *)&longVar);
float2str(longVar,&disp_buffer[4],0);
float2str(mdatahigh,&disp_buffer[16],0);
float2str(mdatamid,&disp_buffer[19],0);
float2str(mdatalow,&disp_buffer[22],0);
void transfer_byte(unsigned char datum) {
unsigned char count,tempbyte;
sclk=0;
tempbyte=0x80;
for(count=0;count<8;count++) {
if(datum & tempbyte) {
sdi=1;
else {
sdi=0;
sclk=1;
tempbyte=tempbyte>>1;
delay(10);
unsigned char receive_byte(void) {
unsigned char count,tempbyte,datal;
datal=0x80;
tempbyte=0;
sdo=1;
if(sdo) {
tempbyte|=datal;
} sclk=1;
datal=datal>>1;
return(tempbyte);
void read_a_reg(unsigned char command,unsigned char * ptr) {
transfer_byte(command);
mdatahigh=receive_byte();
mdatamid=receive_byte();
mdatalow=receive_byte();
*ptr=mdatalow;
ptr++;
*ptr=mdatamid;
*ptr=mdatahigh;
void write_to_reg(unsigned char command,unsigned char high,unsigned char mid,unsigned char low) {
transfer_byte(high);
transfer_byte(mid);
transfer_byte(low);
Didn't you see the note about how to post source code?
Don't you see a difference between the "code" in your post, and this code?
#include <stdio.h> int main(void) { printf("Hello world\n"); return 0; }
Now, what do you think you would have to do to get your code properly indented and with the line breaks where they should be? How about giving it a try?
It really is quite clearly stated:
www.danlhenry.com/.../keil_code.png
If you can miss something that obvious, perhaps you should go back and re-read the P89v51rd2 SPI documentation to make sure you haven't missed any other important details in there...
sorry for not posting the code in wrong format. Now i had understand and re-post it.
I am using Bit Banging instead of On chip SPI module.
#include "p89v51rx2.h" #include <stdlib.h> #include <stdio.h> #include <string.h> #include <math.h> //-----------------------------------ADC CS5463------------------ sbit nreset = P3^3; //RESET PIN OF CS5463 sbit cs = P3^4; //CHIP SELECT OF CS5463 sbit sclk = P3^7; //SERIAL CLOCK sbit sdo = P3^6; //SERIAL DATA OUT sbit sdi = P3^5; //SERIAL DATA IN unsigned char sec_cnt=0; unsigned long longVar=0; unsigned char mdatahigh; unsigned char mdatamid; unsigned char mdatalow; //--------------------- Functions Related to CS5463 --------------------------------- void init_cs5463(void); void main(void) { init_cs5463();//initiallises the cs to function as per our requirements } void init_cs5463(void) { write_to_reg(0x40,PCB,0x80,0x61); //write to config register(0x40) cs=0; transfer_byte(0xe8); // start continuous conversions.. cs=1; //Here is my while loop and try to read the CS5463 register and disply it,but not able //to get any response from the it. longVar = 0; while(1) { read_a_reg(0x40,(unsigned char *)&longVar); float2str(longVar,&disp_buffer[4],0); float2str(mdatahigh,&disp_buffer[16],0); float2str(mdatamid,&disp_buffer[19],0); float2str(mdatalow,&disp_buffer[22],0); } } void transfer_byte(unsigned char datum) { unsigned char count,tempbyte; sclk=0; tempbyte=0x80; for(count=0;count<8;count++) { if(datum & tempbyte) { sdi=1; } else { sdi=0; } sclk=1; sclk=0; tempbyte=tempbyte>>1; } sdi=1; delay(10); } unsigned char receive_byte(void) { unsigned char count,tempbyte,datal; sdi=1; datal=0x80; tempbyte=0; sdo=1; for(count=0;count<8;count++) { if(sdo) { tempbyte|=datal; } sclk=1; sclk=0; datal=datal>>1; } return(tempbyte); } void read_a_reg(unsigned char command,unsigned char * ptr) { cs=0; transfer_byte(command); mdatahigh=receive_byte(); mdatamid=receive_byte(); mdatalow=receive_byte(); cs=1; *ptr=mdatalow; ptr++; *ptr=mdatamid; ptr++; *ptr=mdatahigh; } void write_to_reg(unsigned char command,unsigned char high,unsigned char mid,unsigned char low) { cs=0; transfer_byte(command); transfer_byte(high); transfer_byte(mid); transfer_byte(low); cs=1; }
Did you just cut/paste the code from the original post? Didn't you notice that you still have the exact same source code lines merged to a single line? If that had been possible, then _I_ could have reposted your source code in a readable format.
You have to go all the way back to your source code editor, since the code in your first post is already permanently ruined. Next thing - avoid tab characters for indenting.
Hope this will ok with you.
I really need the solution, it's urgency.
Hope experts will help.
#include "p89v51rx2.h" #include <stdlib.h> #include <stdio.h> #include <string.h> #include <math.h> //-----------------------------------ADC CS5463------------------ sbit nreset = P3^3; //RESET PIN OF CS5463 sbit cs = P3^4; //CHIP SELECT OF CS5463 sbit sclk = P3^7; //SERIAL CLOCK sbit sdo = P3^6; //SERIAL DATA OUT sbit sdi = P3^5; //SERIAL DATA IN unsigned char sec_cnt=0; unsigned long longVar=0; unsigned char mdatahigh; unsigned char mdatamid; unsigned char mdatalow; //--------------------- Functions Related to CS5463 --------------------------------- void init_cs5463(void); void read_a_reg(unsigned char command,unsigned char * ptr); void transfer_byte(unsigned char datum); unsigned char receive_byte(void); void write_to_reg(unsigned char command,unsigned char high,unsigned char mid,unsigned char low); void main(void) { init_cs5463();//initiallises the cs to function as per our requirements } void init_cs5463(void) { write_to_reg(0x40,PCB,0x80,0x61); //write to config register(0x40) cs=0; transfer_byte(0xe8); // start continuous conversions.. cs=1; //Here is my while loop and try to read the CS5463 register and disply it,but not able to get any response from the it. longVar = 0; while(1) { read_a_reg(0x40,(unsigned char *)&longVar); float2str(longVar,&disp_buffer[4],0); float2str(mdatahigh,&disp_buffer[16],0); float2str(mdatamid,&disp_buffer[19],0); float2str(mdatalow,&disp_buffer[22],0); } } void transfer_byte(unsigned char datum) { unsigned char count,tempbyte; sclk=0; tempbyte=0x80; for(count=0;count<8;count++) { if(datum & tempbyte) { sdi=1; } else { sdi=0; } sclk=1; sclk=0; tempbyte=tempbyte>>1; } sdi=1; delay(10); } unsigned char receive_byte(void) { unsigned char count,tempbyte,datal; sdi=1; datal=0x80; tempbyte=0; sdo=1; for(count=0;count<8;count++) { if(sdo) { tempbyte|=datal; } sclk=1; sclk=0; datal=datal>>1; } return(tempbyte); } void read_a_reg(unsigned char command,unsigned char * ptr) { cs=0; transfer_byte(command); mdatahigh=receive_byte(); mdatamid=receive_byte(); mdatalow=receive_byte(); cs=1; *ptr=mdatalow; ptr++; *ptr=mdatamid; ptr++; *ptr=mdatahigh; } void write_to_reg(unsigned char command,unsigned char high,unsigned char mid,unsigned char low) { cs=0; transfer_byte(command); transfer_byte(high); transfer_byte(mid); transfer_byte(low); cs=1; }
No, you haven't!
Look again: where is the indentation? Note how some lines have merged into one!
Again, if you can't spot simple, obvious things like this, how do you expect to find bugs in your code?!
Attention to detail is key!
"not getting any result"
So what debugging have you done to find out why not?
Have you verified that your 'bit-banging' code does actually set the output lines high & low?
Have you verified that your 'bit-banging' code does actually read the input lines correctly?
Have you verified that your 'bit-banging' timing is correct?
Here are some debugging tips & techniques:
www.8052.com/.../120313
www.techonlineindia.com/.../Developing_a_good_bedside_manner.aspx
OK - while I was writing that, you finally did manage to re-post it correctly!
See how much time you could have saved by taking care in the first place?
Now why would you - even for testing - hide an infinite loop inside init_cs5463()? Don't you think that your infinite loop should be in main()?
You have a function transfer_byte() that sends data - why then the generic name "transfer"?
You haven't defined somewhere what phase and polarity you are intending to have.
Are you aware that SPI is always dual-direction? When you listen, there is still data being sent. When you send, there is also data being received.
Why do you invent new names for signals, instead of using the traditional MOSI and MISO?
Have you verified all timing?
Not always - some things are "half-duplex".
To the OP: A link to the datasheet is always helpful...
SPI is dupex even if quite a number of _protocols_ are half-duplex. For half-duplex protocols, it's common to keep the outgoing data line high - the idle state - when receiving data.
Obviously, the datasheets should never be far away. And the source code should contain very clear documentation what SPI mode (polarity, phase), bit rates etc the code is expected to fulfill.
Why on earth are you doing that?
"I am using Bit Banging instead of On chip SPI module."
And why on earth do you think that using bit banging frees you from caring about phase, polarity, timing etc? With bit banging, you must still perform exactly the same actions as the SPI hardware would do.
Why does the "urgency" seem to have disappeared...?
somebody have on chip spi code for 89v51rd2 than pls share.
Thanks in advance.
With the high intensity put into solving problems with the above code, I have to kind of suspect that the bitbanged code was the first code "found" somewhere. And when it didn't work, then the OP got stuck. So now it's time to try to find code making use of the SPI device.
But whatever code is used, it's still important to figure out what is needed regarding timing, configuration, ... Debugging is always needed when implementing programs. How else can it be verified that the code does as expected and that all requirements specified in the datasheets are fulfilled?
