LPC2129 UART Interrupt Enable Problem
Hi
I am trying to receive bytes from UART0 and UART1 in Interrupt mode. I am enabling UART0 and UART1 Interrupt by the following code:
void initUART1_Intp(void) {
VICVectAddr0 = (unsigned long)U1ISR; //Set UART1 ISR Vector Address
VICVectCntl0 = 0x20 |7; //Enable Slot, Set Channel 7
VICIntEnable = 0x80; //Enable Int UART1
U1IER = 0x01; //Enable the RDA interrupt
void initUART0_Intp(void) {
VICVectAddr1 = (unsigned long)U0ISR; //Set UART0 ISR Vector Address
VICVectCntl1 = 0x20 |6; //Enable Slot, Set Channel 6
VICIntEnable = 0x40; //Enable Int for UART0
U0IER = 0x01; //Enable the RDA(Rx Data Available) interrupt
Is there any problem with this code specially at the last lines (U1IER = 0x01; ) and U0IER =
0x01;
My program is stopping here. Its not going after this statement.
Please help.
  • You forgot to read the instructions on how to post source code. Clearly visible just above the text input box.
    Why no code to set any baudrate?
    You should do a
    dummy = U<n>IIR;
    before that last line.
    Your program will fail badly when you enable the interrupts, if you don't have a reasonable interrupt handler to process the interrupts from the device. It's just a question if you have a pending interrupt that gets instantly processed or if you may run for a while until the UART has an interrupt that needs servicing.
  • Thanks Per
    baud rate code is there and its working. Below is the ISR for UART1. At the stating main() function I am transmitting some strings. What is happening that after sending some characters the progrm is stopping.
    void U1ISR(void) __irq                          // Serial Port1 ISR
     U1IER = 0x0 ;                                      // Clear Interrupt
     RecData1 = U1RBR ;
     DataRecBit1 = 1 ;
     U1IER  = 0x1 ;                                          // enable Interrupt
     VICVectAddr = 0x0;                              // return from interrupt
    I have not written anything for FIFO.
    pleae help.
  • U1IER = 0x0 ;
    This does not cleat the interrupt! Reading RBR does. Remove it, but first check the user manual to see what it really does...
  • Don't play with any U<n>IER in the interrupt handler.
    You should look at I<n>IIR to check what the interrupt handler is expected to do, so you know if you should read U<n>LSR, U<n>RBR, U<n>MSR or if maybe you should feed a character to U<n>THR (if you have anything to send).
    Don't use a single byte and a flag for receiving data. If you can only handle a single character at a time, then it isn't really meaningful with interrupts since the main loop must still poll for that single character before it gets overwritten. Do change to a standard ring buffer where the ISR updates the insert position and the main loop processes characters until the read position reaches the insert position.
