Hello.
I'm trying to set up a MCBSTM32C to have a Flash File System using the RL-ARM FlashFS library, but i'm having a bit of trouble i hoped someone could help me sort out.
In the book "Building Applications with RL-ARM" under RL-Flash introduction, there's a section discussing how to set up a Flash-based filesystem.
It calls out for the file FS_FlashPrg.c and FS_FlashDev.h under the folder C:\KEIL\ARM\RL\FLASHFS\FLASH then a subdirectory named according to your flash or microcontroller.
Looking in that folder i have the following folders:
25F640S33 AM29x800BB AM29x800BBx2 AM29x800BT AM29x800BTx2 AT45DB321C AT45DB642D LPC_IAP_128 LPC_IAP_256 SST39x320x STR71x STR75x STR91x
I'm not sure which one would correspond to the STM32F107VC... Do I have to write my own drivers for this controller? If so, is there literature i can obtain covering how to do this?
Thanks for any insight.
- Per
It depends what drive are you intending to use: SD card, USB dongle or internal flash. The drivers for the first two are ready-made in MDK4.20 (examples SD_File, MSD_File), while the driver for internal flash is not.
You can however do the flash driver for STM32F107 yourself. Please read instructions how: www.keil.com/.../rlarm_fs_cvrt_flashprg_c.htm www.keil.com/.../rlarm_fs_cvrt_flashdev_c.htm
You can also check the STR91x flash driver as a reference.
Perfect, thank you. I was hoping i had mentioned the word Flash enough in my post, so yes, I am looking to get a file system for the internal flash. :-)
But surely, this is something that has been done in the past? You would think there would be drivers available already?
anyway, thanks again!
so, I seem to be having a spot of trouble here.
I followed the instructions, but I'm encountering a hard fault when i try the following code:
FILE* fptr = fopen("f:\\test.txt", "w");
Here's what I did:
1. Copied the files FlashDev / FlashPrg from Keil\ARM\Flash\STM32F10x 2. Modified FlashPrg. Everything was pretty straightforward except step 7 and 8. For 7, i encountered 2 chunks of code like:
M16(adr) = *((unsigned short *)buf); // Program Half Word
I ASSUME I just need to add __packed to this so i would get
M16(adr) = *((__packed unsigned short *)buf); // Program Half Word
Is this correct?
for 8, i have no idea if i need to do anything...
3. In FlashDev, i had to go back a few fimes ...
It seemed to call for 2048-byte sectors for the 107-CL, so i created 128 of them in the macro FL_DEVICE.
I compiled (worked) but when i ran the code above, Hard Fault.
I then figured that maybe my File_Config.c is not set up right, so went in there and changed Base address to 0x0800 0000, in accordance with the memory map of the device. and size to 0x0004 0000, also in accordance to the memory map.
This also crashed.
I then realized that my program is using a certain amount of code, so i changed Base Address of the Flash Drive to 0x0802 0000 (up by 0x20000), and changed Device Size to 0x0002 0000 (down by 0x20000). In my mind this would create a flash drive in the range 0x0802 0000 -> 0x0803 FFFF. And as my code was less than 0x10000 bytes, i should be good?)
again a crash.
I poked at the settings for the project and changed 'IROM1 on-chip Read/Only Memory area' to 0x0800 0000, 0x20000 (down by half).
Still crashing.
I'm a bit at a loss here. any insight or knowledge to assist me here, would be greatly appreciated!
thank you.
Ok, an update. I was able to set up Flash as a file system.. but i'm not sure it's working correctly.
To make it work, I had found a reference manual for the 207 with 1024 KB flash, and they say this:
Main memory Sector 0 0x0800 0000 - 0x0800 3FFF 16 Kbyte Sector 1 0x0800 4000 - 0x0800 7FFF 16 Kbyte Sector 2 0x0800 8000 - 0x0800 BFFF 16 Kbyte Sector 3 0x0800 C000 - 0x0800 FFFF 16 Kbyte Sector 4 0x0801 0000 - 0x0801 FFFF 64 Kbyte Sector 5 0x0802 0000 - 0x0803 FFFF 128 Kbyte Sector 6 0x0804 0000 - 0x0805 FFFF 128 Kbyte . . . . . . . . . Sector 11 0x080E 0000 - 0x080F FFFF 128 Kbyte
So i placed the device start at 0x08000000, and sized it to 0x00020000 (128KB) and then in the FS_FlashDev.h I had only one sector starting at offset 0x00020000, and with size 128 KB.
This works - i.e. i can open a file, write to it, and close it. But when I try to use ffind or fopen( ..., "r") on it, i cannot see it.
Any ideas?
Some more information ...
If i try to use any memory area at 0x0802 5800 or higher, the program i have will hard fault with the call stack as follows.
HardFault_Handler() <0800135e()> fs_ReadData() adr <invisible> cnt <invisible> buf <invisible> fs_Find_File() fname 0x00000000 fcb 0x20000090 fa 0x20000b9d8 buf 0x2000b9b4 bl 0x00000000 prev <invisible> fid 0x0000bdf7 __fopen() fname 0x0800048a openmode <invisible> i <invisible> fid 0x2000b9b4 handle 0x00000000 fcb 0x20000090 rval <invisible> _sys_open() name <invisible> openmode <invisible> <080010f2()> main()
if i do not include any addresses above this, it behaves as such:
... fptr = fopen("F:\\test.txt", "w"); if ( fptr != NULL ) { r= fwrite("this is a test", 1, 14, fptr); r= fflush(fptr); r= fclose(fptr); // the code will run to here } fptr = fopen("F:\\test.txt", "r" ); if ( fptr != NULL ) { r= fread(sz, sizeof(char), 14, fptr); r= fflush(fptr); r= fclose(fptr); // the code will NOT run to here }
It seems the file is not written properly in the fwrite call?
