RL-ARM problem with startup.s
Why the startup.s of the RTX-Blinkly of ek-lm3s6965 is different with the startup.s that is created by MDK Wizard?
I am using MDK (version V4.03q) to program lm3s8962 . If I using the MDK wizard to creat a new project and add startup automativly,the kernel can not run. The only way I deal with this problem is to change the device in the RTX-Blinkly example.
The method to start RTX-based project in "RL-ARM Getting Started" seem not corrcet. Could anyone help me to solve this problem?
