Hello!
I am kind of new user of the IDE of Keil uVision and due to the fact that I am not very experienced in the field of programming I am seeking your help.
I use the ADU 7026 of ARM7 and I want to introduce an input to an already existing program that uses apart from other peripherals, the A/D Converter. The input I want to introduce is sine at the adc0 pin. I have created the following initial file but the compiler finds an error as shown:
signal void ADC0_sin(void) {
float value, k;
k = 0 ;
while(1) { k = k+ 10 ;
value= _sin(2*3.14*k); //here is the error : undefined identifier//
adc0=(value * 1.5) + 1.5;
swatch(0.00001); }
I have "linked" the initialization file with the main program by writing on the command window INCLUDE initial.ini . Thus the adc0 in the logic analyzer window indicates that no input has been given when I "run" it.
The answer may be easy or obvious but could anyone help me? Thanks in advance!
