Good Morning,
currently I am working on a mass-storage-solution based on LPC2468 with external flash. I modified the USBMEM-Examples function MSC_MemoryRead, MSC_MemoryWrite, MSC_MemoryVerify and MSC_MemorySize, MSC_Blockcount. The MSD is supposed to be used with a FAT16 filesystem (no MBR, just PBR).
After connecting the device to a PC, the PBR in sector 0 is read, but the following sectors aren't. Using WinHEX i could verify, that even modifying sector 1 (which is hidden, FAT1 begins at sector 32) isn't recognized by the MSD.
Here are the modifications to MSC_ReadMemory function.
[...] NANDFLASHPageRead((Offset &(~(0x1FF)))+FAT_offset_pages<<9 , &Buffer[0], 512); // read corresponding page if ((Offset + n) > MSC_MemorySize) { n = MSC_MemorySize - Offset; BulkStage = MSC_BS_DATA_IN_LAST_STALL; } USB_WriteEP(MSC_EP_IN, &Buffer[Offset%512], n); [...]
I can't figure out, whats wrong. The USBMEM-Example works just fine and I haven't changed anything regarding the MSC except for the functions I've mentioned.
Thank you for reading and hopefully trying to help me.
Regards Frank
This Keil example?
C:\Keil\ARM\Boards\Keil\MCB2400\USBMem or http://www.keil.com/download/docs/336.asp
This MSC example doesn't move sector (block) address on the firmware. The SCSI command parser extracts LBA (Logical Block Address) from CBW using MSC_RWSetup() on "Offset" variable. And the LBA is directly passed to MSC_MemoryRead/Write/Verify routines.
I'm not sure for WinHEX, but many disk tools don't show "physical" address on the target disk directly, but "logical" address, translated one.
Try Disk Probe (dskprobe.exe) by MS. It is included in "Windows XP Service Pack 2 Support Tools" download. " address as the default. To see physical address, - Drives menu > Physical Drive On "Open Physical Drive" dialog, - Double click on "PhysicalDrive0" - Uncheck "Read Only" for Handle 0 - Push "Set Active" button - Push "OK" Specify sector address using Sectors menu > Read
Tsuneo
Good Morning Tsuneo,
I hoped, you would read this. I use the example that's shipped with the MCB2400. As far as I understand, the PC sends READ10 and the LBA of a sector. The LBA can be treated as offset for the memory's addressing-area.
I tried Disk Probe, reading different addresses and different read-length. Accessing any sector other than sector 0 returns an erased flash page (everything 0xff), even where the FAT is located. Reading more than one sector has no effect, Disk Probe returns only one sector.
Seems, that there's an adressing problem in the MSC (at least while not accessing sector 0) AND only one sector is getting read, regardless of the length I specify.
On the stack, MSC_MemoryRead() is called repeatedly, even for single sector read. The sector size is 512 bytes (MSC_BlockSize), but the max packet size of the bulk endpoint (EP) is 64 bytes. 512 bytes sector is split into 8 transactions (packets) over the bulk EP. ie. MSC_MemoryRead() is called 8 times for single sector read.
When MSC_MemoryRead() is called once, 64 bytes packet is passed to the endpoint by USB_WriteEP(). MSC_MemoryRead() moves "Offset" variables for the next 64 bytes packet.
In your code, NANDFLASHPageRead() reads out 512 bytes at a time. Is there any problem when NANDFLASHPageRead() is repeatedly called?
Hello Tsuneo,
Reading the sector multiple times is no problem. I tried various modifications today. For now I am able to read the first 128 sectors (MSC-blocks) without any problem. What I did was to number the sectors in the flash. The first two bytes contain the block- and page-address. The output of disk probe and WinHex shows correct the sector-numbers. Therefor I had to modify the LBA, which seems pretty weird. In the example the LBA is extracted off the CBW and then multiplied by the sectorsize to get the final byte-address. In my case the LBA had to be divided by 512 to get the byte-adress. I can't really explain the reason, I've just found out (by numbering the sectors), that the MSC read every 512th sector.
By now the problem has moved. I can read the first 128 sectors, but the next 64 sectors being read start at sector 0 again with an offset of 128 Byte. Same thing happens every 128 sectors. Maybe I'm just blind for the problem, so here's the code:
void MSC_MemoryRead (void) { u32 n; for(n=0;n<16384;n++) Buffer[n]=0x00; if (Length > MSC_MAX_PACKET) n = MSC_MAX_PACKET; else n = Length; if ((Offset + n) > MSC_MemorySize) { n = MSC_MemorySize - Offset; BulkStage = MSC_BS_DATA_IN_LAST_STALL; } NANDFLASHPageRead(Offset/512+FAT_offset_pages<<9 , &Buffer[0], 512); // entsprechende Page einlesen USB_WriteEP(MSC_EP_IN, &Buffer[Offset%512], n); Offset += n; Length -= n; CSW.dDataResidue-=n; if(Length==0) BulkStage = MSC_BS_DATA_IN_LAST; if (BulkStage != MSC_BS_DATA_IN) { CSW.bStatus = CSW_CMD_PASSED; } }
As there seems to be no way to debug the MSC-functions inside the IDE, i'm a bit stuck right here. Maybe I'm blind and just don't see the/my mistake.
Greetings Frank
Hello Tsuneo
finally I made it working. I forgot brackets in the makro FAT_offset_pages. This totally screwed up the addressing.
For now I can read the device using Disk Probe and WinHex, what doesn't work is opening a testfile via windows explorer. I guess, that windows needs correct working write-functions for opening a file.
Thanks a lot! Frank
