Open / Select file from Project window
I have found a litle bad habit in the new 4.14.4.0 / 4.14...
if you have all your files closed in the project you can open the file by double click the file in the project window, that is ok.
But if the file allready is open and you double click the file in the project window it will not show/open this file.
I always used this feature becease when many files are open it is hard to find it in the tabs and they can swap place etc...
Do you have some issue in the new release?
Kasper
  • That problem has existed at least all the way back to version 3.
    Sometimes, it fails to bring the clicked source file to top. If I then click on another file it will get to the top. I can then click on the original file name and it will get to the top.
    So somehow, the IDE falsely thinks that the file I click on in the project tree is already on the top and that nothing needs to be done.
    I have reported the bug to Keil twice, but never seen it solved. Not sure if my bug reports have been lost, if they can't reproduce or just haven't thought it important to look at.
  • Hello,
    I think it has been worse now than last release, it seems it will newer bring the file up now if they are open, before i had "no" problem
    Kasper
